Results 1 to 13 of 13
Thread: My TA is 350. Should I lower it?
    Pysiek's Avatar
    Apr 2012
    Frankfort , Illinois
    419
    My TA is 350. I have a water fountain to speed up the process. But is it worth it? Is the TA important if my pH stays the same most of the time?
    30'x54" Quest Above Ground Round Pool , About 21,000 Gallons , Hayward Perflex EC50 D.E. Filter System 1.5HP Power-Flo Pump , TF-100 Test Kit , Two Hayward Main Drains on the Bottom , Hayward CL200 In-Line Above-Ground Chlorinator.
    77"x77"x21.5" Hot Tub
    Jan 2013
    Houston, TX
    1,079
    Re: My TA is 350. Should I lower it?
    If your pH is stable there really isn't any reason to worry about TA. The exception would be if you had an inground plaster pool and were approaching CSI issues.
    TFP Moderator Chris V. ~16K Pool & Spa, 48NSF DE, IG Plaster Circa 2000, Intermatic PE653, Challenger pump with a 2 speed B2984, 20gal stenner chlorine injection, Houston, TX
    One cannot follow Islam and Christianity at the same time, nor can one follow pool store methods and TFP at the same time.
    Pool School -- Pool Math -- TF-Test Kit
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    19,065
    Wow, that's really high!
    Are you absolutely positive there was no testing error? Two possibilities come to mind: 1) it's a fresh bottle of R-009 and you have the static electricity problem that causes the drops to be smaller than they should be, which means more drops needed, which means artificially high TA readings. 2) You're using test strips and your pH isn't as stable as you think.
    Jan 2013
    Houston, TX
    1,079
    That sound ... is me banging my head on the desk for answering a post before my 2nd cup of coffee. Thanks for the catch on astronomically high TA Richard.
    Pysiek's Avatar
    Apr 2012
    419
    I tested 3 days in a row and same all the time. Same problem last year. TA was over 300 after I fill the pool. I'm using TF-100 kit and just ordered a replacement kit since my TA bottle is almost empty.
    I didn't think about it till now but I have a Hanna HI 755 Alkalinity Checker (digital I used for my marine aquarium) and saltwater test kit for marine aquarium. I will try with these and see if it close to what I get with TF-100
    Pysiek's Avatar
    Apr 2012
    419
    I checked again last night and it is at 310 right now. It went down because I lower it with acid and aerate.
    Mar 2007
    San Rafael, CA USA
    12,082
    This page indicates that the water in Frankfort is very, very hard. 31-36 grains per gallon (GPG) is 531-616 ppm total hardness so probably around 400 ppm CH. Oftentimes, when the CH is high the TA is also high, though 300+ is pretty darn high.
    Pysiek's Avatar
    Apr 2012
    419
    I will re check it again once the TF-100 refill kit arrives. But I'm pretty sure it will be the same. Also I do have water softener
    Mar 2007
    San Rafael, CA USA
    12,082
    A water softener will lower the CH replacing calcium and magnesium with sodium, but it won't lower the TA.
    Pysiek's Avatar
    Apr 2012
    419
    Received replacement kit for tf100 last night. Testes water again for TA and it is 310
    Isaac-1's Avatar
    SW Louisiana
    6,711
    What is the pH of your fill water?
    Ike
    I also have ridiculously high TA, and I've learned not to worry so much about it. The fill water routinely tests 400-ish, and the pH is fairly stable. The Calcium is a tad high (don't recall the last test result), but no issues.
    Since I started reading TFP and quit granulated chlorine and then the tabs (went to liquid with a slow peristaltic pump), my pool is clean, clear, and has been as trouble free as a 144,000 gal pool can be.
    In-ground Plaster 40' X 80' 144K gallon pool w/ 2 pumps (old Challenger bronze and newer Challenger II plastic) and 2 large sand filters (Pentair Triton 140's). Built in '85, in bee-yootiful shady Buffalo Gap, West Texas.
    Pysiek's Avatar
    Apr 2012
    419
    Quote Originally Posted by Isaac-1 View Post
    Ike
    I never tested my fill water. But in the village report it says it is 7.0 pH. Right now my pH in the pool is about 7.5
    Quote Originally Posted by jamyers View Post
    That is a big pool! I think I will lower the TA anyway.
