Thread: DRY-NICHE lights, are they a good choice?
    May 2014
    Ontario, Canada
    29
    Hi,
    I just watched a video from "Medallion Pools" on pool walls & seating where he quickly demonstrated a "DRY-NICHE" light set-up. The whole system remains dry, and you easily replace the light (incandescent or LED) by reaching into a skimmer type basket/niche in the deck area.
    This appears to be a great set-up, anyone can then change the light, you have the option of LED or incandescent...
    Am I missing something? Why hasn't my pool builder mentioned this type of lighting?
    Anyone have an opinion on this light set-up?
    Thanks
    Re: DRY-NICHE lights, are they a good choice?
    Dry niche lights are generally more expensive and less reliable than normal lights. In most cases they do eventually get wet, one way or another, and then have problems.
    May 2014
    Ontario, Canada
    29
    I figured there had to be a down-side! True, if there is a lot of splashing & add salt from SWG into the equation... I can see corrosion issues happening. I won't even bring it up as an option with our PB.
    Thanks
