Results 1 to 10 of 10
Thread: Pool skimmer basket and pump skimmer basket
    Pysiek's Avatar
    Apr 2012
    Frankfort , Illinois
    419
    Here is my problem. Pump goes off and the basket in pool skimmer floats to the top and pushing on the "flapper" (I think this is how you call it) when pump goes back on basket won't sink fast enough and block the "flipper" which prevents water flow into the skimmer.
    Even if I have not explain correctly a lot of you probably knows what I'm talking about. Can I just remove the basket from the pool skimmer? And use only the one by the pump?
    30'x54" Quest Above Ground Round Pool , About 21,000 Gallons , Hayward Perflex EC50 D.E. Filter System 1.5HP Power-Flo Pump , TF-100 Test Kit , Two Hayward Main Drains on the Bottom , Hayward CL200 In-Line Above-Ground Chlorinator.
    77"x77"x21.5" Hot Tub
    Smykowski's Avatar
    Sep 2011
    3,065
    Re: Pool skimmer basket and pump skimmer basket
    No, you want the basket to catch big stuff so it doesnt clog the impeller. One solution is to use a rock to weigh down the skimmer.
    Pysiek's Avatar
    Apr 2012
    419
    Quote Originally Posted by Smykowski View Post
    But I will leave the basket in by the pump just remove the one in the skimmer in pool wall
    astronaut888's Avatar
    Jun 2013
    southeast
    118
    I wouldn't consider removing skimmer basket due to safety concerns, personally.
    Also, my son would likely send god know what into the **** thing as soon as the basket was left off for any appreciable time
    20K gal, IG vinyl, 1 1/2 HP Hayward Super Pump , 100lb sand, installed 2000 - new liner/filter/pump March 2014
    TF-100 test kit
    30,419
    Use the rock. It's a bulletproof solution and the price is right.
    Don't remove either basket.
    Mod Squad JohnT's Avatar
    SW Indiana
    9,199
    Just as a note to others reading this thread, make sure the rock is bigger than the opening in the bottom of your skimmer. Not a huge deal with an AG pool, but dropping the rock into the skimmer while cleaning the basket on an IG pool could prove costly.
    steveg_nh's Avatar
    Oct 2013
    Southern NH
    828
    +1 on both the rock, and making sure it can't fit through the hole in the skimmer.
    24'x40' 25k gal Imperial Mountain Pond IGP, full 28 mil VynAll Ocean Breakers liner. All Hayward system: 140k BTU HeatPro heat pump, 3/4HP single speed TriStar 2" Pump, DE6020 filter, AquaPlus Automation/Salt Chlorination, remote controls, ColorLogic 4.0 lighting. Polaris 280 w/PB4-60 BP. TF100 & K1766 test kits. Rinox Palazzo pavers and Spherik coping. Pool installed 9/2013, project completed 6/16/14.
    Pysiek's Avatar
    Apr 2012
    419
    Thanks guys. Will have to find a decent size rock then. Maybe I will borrow my wife's wedding ring
    steveg_nh's Avatar
    Oct 2013
    Southern NH
    828
    I tried to find one that wasn't too flat too, so as to not block to much flow...
    Pysiek's Avatar
    Apr 2012
    419
    I might go to the beach over the weekend and look over there. I'm pretty sure I can find something there
