Page 1 of 3 123 LastLast
Results 1 to 20 of 49
Thread: Just getting started
    May 2014
    Dallas, Tx
    72
    Hi there.
    Pool - 42000 gallons
    Using a K 2600 test kit, results are:
    FC- 1.8
    CC - 0
    PH - 7.8
    TA - 100
    CH - 650
    CYA - 110
    I have been adding 3 gallons of bleach a day but cant get the FC any higher. Poolmath says we should add over 2000 oz of bleach and drain 50% of the pool water. My question is if I need to do both or is it an either or? Thanks for your help.
    Re: Just getting started
    You need to reduce the CYA first, then retest to find CYA again as it may not get to the anticipated value. Then add chlorine based on that to get to shock level if the pool is not clear or if it looks good then go to the upper level of your FC range. Monitor the pool closely to see if it is holding chlorine well.
    You may need to slam the pool. I suspect you might bout it is possible that it will be OK once you get CYA under control.
    No more tabs or dichlor shock for this pool.
    Butterfly's Avatar
    South Carolina
    10,045
    Did you do the dilution test for the CYA?
    What is the CH of your fill water?
    Welcome to the forum
    You're done SLAMing when:
    May 2014
    Dallas, Tx
    72
    Okay - much appreciate the responses. The dilution test for the CYA = 110
    The CH of the fill water is 200. We stopped using the dichlor last week and got rid of the tabs this weekend.
    Butterfly's Avatar
    South Carolina
    10,045
    Okay, good.
    Quote Originally Posted by anonapersona View Post
    What anona said is the way to go ^^^^^
    Let us know when you get the CYA down and post a new set of test numbers.
    Also, we'd love to see a pic or two of your pool
    May 2014
    Dallas, Tx
    72
    Taking about half of the pool water out as we speak. Will fill and post new new test numbers when completed. Thanks for your help. Be glad to post pictures but cant figure out how to get them to upload. I think they are too big. Will keep trying.
    Mike
    Pool is inground 20' x 40' 42000 gallon, rectangular plaster about 60 years old, replastered 2 years ago. Pentair VS Intelliflo pump, Pentair 420 Clean & Clear Plus Cartridge filter. Using K-2006 test kit.
    May 2014
    Dallas, Tx
    72
    Mike
    Butterfly's Avatar
    South Carolina
    10,045
    That's a big pool! And it looks like there is plenty of decking to make lotsa folks happy
    May 2014
    Dallas, Tx
    72
    Okay - Drained half of the pool and refilled, after 2 hours of running the test results are:
    FC - 0
    CYA - 55(standing outside with my back to the sun)
    PH - 7.8
    TA - 90
    CH - 460
    Recommendations? and thanks again for your help!!
    Mike
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    19,065
    Quote Originally Posted by mbeck5 View Post
    FC - 0
    PH - 7.8
    TA - 90
    CH - 460
    Get some bleach in there, target something like 9 or 10, let that mix half an hour, then adjust pH to maybe 7.4. Another half an hour and recheck pH, FC, CC, and TA. If you're holding FC above 9 and CC is staying down below .5, go swimming. If not, post results and await the instructions to SLAM...
    May 2014
    Dallas, Tx
    72
    Richard - Had to leave this morning but added 6 gallons of bleach which according to poolmath should have brought FC up to 7.5. Just did the test and
    9:00 am 2:00 pm
    FC - 0 2.4
    CYA - 55(I do have some trouble with this test 60 then did the dilution test and showed 60 - 65
    PH - 7.8 7.8
    TA - 90 80 (at 8 drops of R -0009 solution turned blue, at 9 drops, turned clear
    CH - 460 500(did both tests with 25 and 10 ml)
    I have washing soda if the PH needs to go down. Thanks for your patience
    9:00 am 2:00 pm
    FC - 0 2.4
    PH - 7.8 7.8
    Mike
    May 2014
    Dallas, Tx
    72
    I messed up with the statement on washing soda, should have said I have Muriatic Acid. Sorry
    Mike
    Richard320's Avatar
    Jan 2010
    19,065
    Understood. Yes, whenever pH hits 7.8, lower it to 7.2.
    It looks like something is growing in there, so a SLAM is called for. You lost an awful lot of FC in 7 hours. Did you measure CC? Since the water is clear, it should go quickly. Adjust the pH with acid, give it half an hour to mix, and hit it! It's going to take a lot of bleach for a pool that size. Just follow those instructions exactly. Your target FC with 55 CYA is 22. Yes, really. That will kill off algae faster than it can reproduce.
    May 2014
    Dallas, Tx
    72
    Yes, the CC was zero. Going to start the acid now. Thanks again, will post results tomorrow morning.
    Mike
    May 2014
    Dallas, Tx
    72
    Well, I put 13 96oz bottles of bleach in the pool at 3:00. Just tested the water(8:00) and the FC is 7. Should have been 22 according to PoolMath. Asked my wife to do the CYA test with no explanation other than the dot and she came up with 55. Then asked her to do the dilution test and she came up with 60 so it doesnt appear to be the CYA level. What do you think? Will test again in the am.
    Mike
    May 2014
    Dallas, Tx
    72
    Well, I put 13 96oz bottles of bleach in the pool at 3:00. Just tested the water(8:00) and the FC is 7. Should have been 22 according to PoolMath. Asked my wife to do the CYA test with no explanation other than the dot and she came up with 55. Then asked her to do the dilution test and she came up with 60 so I guess its not the CYA level. What do you think? Will test again in the am. CC was zero. The water is beautiful!!
    Mike
    May 2014
    Dallas, Tx
    72
    Good morning!! Test results at 7:30 am
    FC - 7.2
    CC - 0
    PH - 7.4
    TA - 90
    CH - 500
    CYA - 70
    Did FC, PH and CYA twice with my wife to confirm the numbers. Independently, we agreed. Water is sparkling. Recommendations? CH that high damaging to the pool?
    Mike
    May 2014
    Dallas, Tx
    72
    Also tested the tap water CH and its around 250
    Mike
    Richard320's Avatar
    Jan 2010
    19,065
    FC - 7.2
    CC - 0
    PH - 7.4
    TA - 90
    CH - 500
    CYA - 70
    At 7:30, the sun's already been hitting the water, so it wasn't an overnight loss test. The amount of chlorine your pool sucked up the day before is still alarming. I would keep it at SLAM one more day and try to do the overnight loss test precisely tomorrow morning. A couple extra jugs today could save a couple dozen over the weekend.
    500 CH by itself will not damage the pool. Combined with high pH and high TA, it can lead to scaling. Check my reply #8 in this thread.
  20. Back To Top    #20
    May 2014
    Dallas, Tx
    72
    Thank you for the quick response. If I understand you correctly that would mean to add 10 jugs to reach the SLAM level of 28 per the chart. Is that correct?
    Mike
