Results 1 to 14 of 14
Thread: PH
    careingemt's Avatar
    Sep 2013
    PA
    143
    PH
    Any tips on reading PH
    Hard to distinguish colors with tf100 kit
    AG 18 feet accross 52" high pool wall 7000 gallons .... pool math = 7600
    Hayward extreme cartridge filter 100sq feet
    pool is heated by propane Hayward heater
    pool installed aug 12 2013
    Butterfly's Avatar
    South Carolina
    10,045
    Re: PH
    Yeah, the pH test can be challenging for some of us. Sometimes 'reading' the colors helps:
    yellow 6.8 and lower,
    yellow orange 7.0 ,
    orange 7.2, orange red 7.4-7.5,
    red 7.6-7.8,
    red violet 8.0 ,
    violet 8.2 and higher
    If the color is orange red to red with no pink or violet you are golden.
    How do you test? Hold comparator block in front of white background? ....against blue sky? etc.
    You're done SLAMing when:
    careingemt's Avatar
    Sep 2013
    PA
    143
    Re: PH
    In garage with florescent lights and two 40 watt bulbs dark outside .....
    Butterfly's Avatar
    South Carolina
    10,045
    Re: PH
    Scroll down to post #5 for more info:
    http://www.troublefreepool.com/threa...Kit-Directions
    careingemt's Avatar
    Sep 2013
    PA
    143
    Re: PH
    Awsome info ..... BUT when testing pH am I not suppose to use phentol red
    careingemt's Avatar
    Sep 2013
    PA
    143
    Re: PH
    Sometimes its hard to get some free time so I test after son goes to bed
    Butterfly's Avatar
    South Carolina
    10,045
    Re: PH
    Quote Originally Posted by careingemt View Post
    Sent from my XT907 using Tapatalk
    quote from Post #5
    R-0004 and R-0014 are phenol red, an organic dye that changes color with pH.
    careingemt's Avatar
    Sep 2013
    PA
    143
    Re: PH
    Will have to see which one I have at home at work now will post when I get home
    May 2014
    Hunterdon County, NJ
    32
    Re: PH
    I usually do all my testing indoors usually in the evening or at night. I have always had a difficult time with the PH readings, no matter where I do it. Since I log my daily tests on my computer, I have found that opening a Blank Word processing screen and holding the test cells close to the screen at arms length gives me the best results. The other option is possibly hold it with the Speed Stir LED's on behind it. I would love a good, accurate, affordable, Ph test that didn't require me to have to compare colors.
    20500 gallon Grecian type 2 pool built in 1980's, Vinyl liner approx 2001
    2 Skimmers, 1 Dedicated Vac Line and 3 returns
    PureLine Prime PL2601 Pump - Hayward in line Chlorinator
    Triton TR-60 Sand filter
    Dolphin M3 robot, TF-100 with XL option & Speed Stir
    careingemt's Avatar
    Sep 2013
    PA
    143
    Re: PH
    Thanks
    Oct 2013
    Chapin, SC
    1,141
    Re: PH
    Quote Originally Posted by ump107 View Post
    We all wish for that!
    Pool size: 24000gal inground Vinyl-Taylor k-2006 and k-1766 test kits and-speed stir
    Intermatic P1353ME digital timer w/freeze sensor
    CircuPool Si-45 SWCG System
    Polaris 280 vacuum/Polaris PB4-60 boost pump
    Pentair IntelliFlo VS 3hp Pump--Pentair sand filter
    careingemt's Avatar
    Sep 2013
    PA
    143
    Re: PH
    I have Phenol red 0014
    38,262
    Re: PH
    Yup, that comes with the TF-100. The R0004 is for the larger water sample that the K2006 and others use.
    Fyi, I just found some R0015 in one of my old kits (very old, but seems to still work) and added it to the pH test. It is for the acid demand test which is nice to play with and get a feel for the color changes.
    steveg_nh's Avatar
    Oct 2013
    Southern NH
    825
    Re: PH
    Someone on here told me to shoot for "peach" as the color. That describes it well. Yellowish is too low, reddish/pink too high. Peach, just right!
    24'x40' 25k gal Imperial Mountain Pond IGP, full 28 mil VynAll Ocean Breakers liner. All Hayward system: 140k BTU HeatPro heat pump, 3/4HP single speed TriStar 2" Pump, DE6020 filter, AquaPlus Automation/Salt Chlorination, remote controls, ColorLogic 4.0 lighting. Polaris 280 w/PB4-60 BP. TF100 & K1766 test kits. Rinox Palazzo pavers and Spherik coping. Pool installed 9/2013, project completed 6/16/14.
