Thread: ALK & HRD low, does it mater?
    Jun 2013
    SW OKC
    29
    Using a HTH 6way test kit, here are the results.
    CL/BR 1/2
    PH 7.2
    ALK 30
    HRD 60
    CYA 30
    Looks like alk & hrd are low, how do I raise them up?
    I'm fixing to add salt and then get the saltwater system going, but trying to get all my numbers right first.
    18x48 Intex Ultra Frame, 6,423gal, 1500gph Cartridge, SWG, Setup June 2013.
    UN1017's Avatar
    May 2012
    Sacramento, CA
    288
    Re: ALK & HRD low, does it mater?
    First off, you've got to get some bleach in there to get your FC up. For a CYA of 30, you never want it below 2. Also, you can ignore the Br portion of the test block. It only for Bromine (spas).
    You can take a little spin through Pool School to see what your levels should be and what chemicals to use.
    Also, be prepared to bump your CYA up once you fire up the SWG.
    15'x30' IG - Roman-style - 14K - Pebble Fina Classico
    Filter: Jandy CL460 Pump: Jandy Stealth SHPF1.5 SWG: Jandy AquaPure 1400 Cleaner: Jandy RayVac Test Kit: TF-100 w/SpeedStir
    Chlorine/CYA Chart----Extended Test Kit Directions----SLAM
    Hardness low is just fine in a vinyl liner pool, but alkalinity low should be adjusted up.
    Jun 2013
    SW OKC
    29
    Forgot to mention this was after having about 5 kids swimming for a couple hours, before they got in the FC was high from shocking it.
    Ok, so bleach, alk, and cya need to come up. If I add bleach will that raise any of the others? Thanks
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    19,067
    Quote Originally Posted by Jeff405 View Post
    No.
    Bleach raises FC
    Baking Soda raises Alkalinity
    Cyanuric Acid aka stabilizer raises CYA
    This article explains things in more depth, and also tells the proper way to add each
