Thread: Hayward PS4 valve 3 and 4
    Apr 2014
    San Antonio TX United States
    13
    Can I use the valve 3 and 4 buttons to open and close 2 valves actuators without loosing my current 2 Aux's? Current set up is pool only with PS4. I have a Hayward VS tristar on relay 1 and my colorlogic 4.0 on relay 2. Aux 1 is my booster pump and Aux 2 is my landscape lights. From the manual it reads like i can, but my pb says no way. Thanks
    38,521
    Re: Hayward PS4 valve 3 and 4
    Yes. The valves 3 and 4 are normally completely independent of the aux relays. There is a setting that makes the valve controls switch with the aux control, but not by default.
    Edit: actually I was wrong. The setting makes valve 1 and 2 be slaves to the aux 1 and 2. Valve 3 and 4 are always independent.
