Thread: Conundrum
    jamesd8's Avatar
    Apr 2014
    San Diego
    42
    Conundrum
    Just set up pool and filled with water. I set up upgraded sand filter and came to the realization that the hose adaptors aren't compatible with pool inlets. So I ordered on Amazon. Problem is it'll be a week before they arrive and I don't want a pond by the time they get here. Can I treat with chemicals while I wait to get system up and running?
    Intex 15'x4' round AG metal frame pool, 4400 Gallon, Krystal 14" 2150GPH Sand pump/filter .75HP. Taylor 2006 test kit. San Diego, CA.
    Charlie_R's Avatar
    May 2013
    Mexico, MO
    2,156
    Re: Conundrum
    Yes, you can at least keep chlorine in the water, and stir it around with a brush or sump pump. Anything to get the water moving.
    Be aware that your tests will likely be off a bit, without full circulation.
    jamesd8's Avatar
    Apr 2014
    San Diego
    42
    Re: Conundrum
    Thank you!
    Should I hold on the the stabilizer?
    Re: Conundrum
    Correct, wait on CYA until you have the pump running again. In the meantime, add 2 ppm of chlorine each evening after the sun is off the pool.
