Results 1 to 10 of 10
Thread: CYA Question
    CYA Question
    HEY ya'll!! I figured I better get in here with a question so you don't forget me. We've had tons of rain, and my readings have been all over the place.
    My CYA reading is at 20 (way too low..) I added 16 oz of cya yesterday in a sock in front of a return and have been running the pool since then. Sock is empty. When will I be able to see a difference in the reading?
    Pool Calc says 96 oz of cya to got back to normal. I am putting another dose in now.
    Here is what I have today:
    PH - 7.5
    FC - 6
    CC - .5
    TC - 6.5
    TA - 70
    CH - 200
    CYA - 25
    SALT - 3200
    TEMP 72
    LOOKS CLEAR
    Thank you in advance!
    Helen
    Dallas Area, 16,000 gal IG, Easytouch 8 computer, Intelliflo 3HP Variable Speed pool pump, Pentair Smart Pump 4x160, Pentair 3/4 HP Booster Pump, FNS 60 DE 60, Mastertemp 400, Rainbow 320, Dual Timer w/ freeze protection, Intellichor SWG, TF100 Test Kit, POOL FILLED AUG 3, 2012, ORDER YOUR TF100 KIT FROM http://tftestkits.net
    http://www.troublefreepool.com/under...ie-t49936.html
    pwrstrk's Avatar
    Elverson Pa.
    4,758
    CYA Question
    It usually takes up to week for the CYA addition to fully register on a test. When it's all dissolved just assume it's there.
    Watch you don't over shoot your desired level. You know the pain it is to lower it. 😎
    Jeff
    frustratedpoolmom's Avatar
    SWSuburban Chicago, IL
    11,969
    Re: CYA Question
    What brand was it? Some brands are only 50% CYA so double check the active ingredients....
    Re: CYA Question
    Thank you pwrstrk.. (yes, it sure is a pain.) Should I just do half or 3/4 of the 96 oz, then take a reading?
    Quote Originally Posted by frustratedpoolmom View Post
    Thank you! It is SPLASH-READY from Home Depot. I just looked and it is 97% CYA. (I would have made a terrible chemist.. I didn't even look at that.)
    Helen
    pwrstrk's Avatar
    Elverson Pa.
    4,758
    Re: CYA Question
    I would do 3/4 and see where that puts ya. 😎
    Jeff
    Jul 2013
    Runnemede, NJ
    58
    Re: CYA Question
    Definitely go low on the add! I just had to drain and refill 1/2 the pool twice....
    21' Round Ovation Impact, 54" wall. Hayward AquaTrol SWCG, Hayward 1.5 HP pump, Hayward S180T sand filter, Aqualuminator with fountain attachment, Taylor K2006C test kit
    Re: CYA Question
    Quote Originally Posted by pwrstrk View Post
    I would do 3/4 and see where that puts ya. ��
    Will do.. s l o w l y!
    TU!
    Quote Originally Posted by firefighter75 View Post
    TU! I put the "sock" in front of a return in the spa... seems to have more "blow" than in other parts of the pool. Which means quicker dissolve I suppose.
    Helen
    Re: CYA Question
    I tied the sock to a clorox jug and let the CA do it's thing. I went out of town for the weekend and came home to a very swollen bottle of clorox. (It's been hot here.) Think it will explode? I'm not sure what to do with it. I was thinking of letting out the air/gas build-up then tossing it.
    Helen
    38,528
    Re: CYA Question
    I assume there is no bleach in the bottle? Just slowly open it and let the hot air out.
    Re: CYA Question
    Well, It was a full jug of bleach. I ended up putting it in the shade - the bottle shrunk back to normal. Then I tossed the bleach, probably no good after the sun. Thanks!
    Helen
