Thread: Air Bubbles
    May 2014
    Upstate NY, US
    64
    Air Bubbles
    I was sitting on the deck watching the pump and such work (hey, we finally got it all working and no leaks, so I'm happy). So I was sitting there and I heard a burbling noise, I ran down to check on everything, pump ok, filter ok, pressure ok (16 psi), no leaks. But there was a string of bubbles that came out the discharge from where the pump returns the filtered water into the pool. Only happened once. Any ideas on the cause or is this no big deal?
    My pool: 13,500 gallons round pool, 24' w 52" above ground, hard sided pool. Jacuzzi 190L Sand Filter, 1 Horse Waterway pump, Robotic Vacuum
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    19,051
    Re: Air Bubbles
    It could have been a sticking weir. When the water level dropped inside the skimmer well to allow a vortex, the weight of the water piled up behind it in the pool pushed it open.
