Thread: TF-100 question
    May 2014
    Norfolk, VA
    1
    TF-100 question
    Hi. I am just starting out testing my own water when I opened today and used the TF-100 for the first time today when opening my 18' AG. When using the TA test once I did step 2 with R-0007 and then R-0008 my solution was already red instead of green. This was before step 3. I ran the test three different times about 2 hours apart and still have the same results. Can anyone please tell me what I need to do to fix this?
    FC-7
    TC-7
    Ph-too low to tell
    CYA-50
    7500 gallon AG
    Sand Filter
    Administrator Leebo's Avatar
    Jul 2011
    Eastern Ohio
    7,086
    Re: TF-100 question
    What have you used to chlorinate your water?? You need to raise your pH up to at least 7 to avoid damaging various items. Your TA is very low to zero at this point. Here's a quote from the Extended Test Directions.
    Add 5 drops of R-0008 and swirl to mix. The solution should turn green or blue. If the sample turns red, pink, or yellow, you are done, your TA is zero, and your PH is very very low.
    Jun 2013
    Indiana
    57
    Re: TF-100 question
    so using the pool math calculator at www.troublefreepool.com/calc.html you need to add borax to raise the PH and baking soda to raise the TA
    IG plaster, 22,000 gallon, Jacuzzi Laser Sand filter
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    19,000
    Re: TF-100 question
    Slow down!
    And welcome
    If the water hasn't had a chance to circulate and mix, you might just be testing a layer of snowmelt, which of course will be free of alkalinity. So don't start tossing stuff in the pool if the water hasn't had a chance to mix well!!
    If those reading are accurate, then you need to add some alkalinity with Baking soda, target maybe 50, then recheck pH and TA after it's mixed for a good hour, and then raise pH with Borax. Let that mix, and recheck your numbers again. It may take a few adjustments to get things right.
    elwood58's Avatar
    May 2012
    Sun City West Arizona (2nd Home)
    653
    Re: TF-100 question
    A layer of snow melt would not have a CYA of 50, but Richard is right, you need to let things mix well to avoid over adjustment. Getting that PH up above 7 is critical.
    19204 Gallon L Shape with a 10X10 2nd Step Baja Ledge. Intellichlor IC-40, IntellipH, Cartridge Filter, Pentair Heater/Chiller (Heat Pump). Tons of Deck with Deck Jets. Construction Complete 6/5/17.
    "If you don't measure it, you can't manage it!"
