Results 1 to 7 of 7
Thread: Keep pump running?
    May 2014
    Clinton,Iowa
    42
    Keep pump running?
    Should you leave your pump running 24/7 or not. I have heard both to keep it running and some keep it on a timer?
    28' Above Ground Pool, 20,000 Gallons
    Sand Filter"
    Model #AC16985
    Pool built in July 2012
    Clinton, Iowa
    Jan 2013
    Houston, TX
    1,079
    Re: Keep pump running?
    For most residential pools less than 8 hours is sufficient. It really depends on you pump, filter and personality of pool.
    TFP Moderator Chris V. ~16K Pool & Spa, 48NSF DE, IG Plaster Circa 2000, Intermatic PE653, Challenger pump with a 2 speed B2984, 20gal stenner chlorine injection, Houston, TX
    One cannot follow Islam and Christianity at the same time, nor can one follow pool store methods and TFP at the same time.
    Pool School -- Pool Math -- TF-Test Kit
    mas985's Avatar
    Pleasanton, CA
    11,741
    Actually for most residential pools, only 4 hours is necessary.
    At least according to this report:
    http://consensus.fsu.edu/FBC/Pool-Ef...on_systems.pdf
    Plus my own experience.
    Mark
    May 2014
    Clinton,Iowa
    42
    Interesting reading, with that, is there a special timer for outdoors that can be used? Thanks for all the help.
    Sand Filter"
    Model #AC16985
    Clinton, Iowa
    mas985's Avatar
    Pleasanton, CA
    11,741
    Intermatic makes several outdoor timers.
    http://www.amazon.com/Intermatic-T10...&keywords=T104
    They also make several two speed timers for two speed pumps.
    Mark
    May 2012
    Toronto, ON
    463
    My pool heater, a Jandy Lite 2, has a simple on and off timer. But if you have a SWG or solar panels then you may want it to run more.
    Vinyl 18'x36' in-ground 100,000 L, Jandy Aquapure 1400 SWCG, Jandy Lite2 heater, StaRite System3 filter, Evac tube solar heating panels
    May 2014
    Clinton,Iowa
    42
    Sand Filter"
    Model #AC16985
    Clinton, Iowa
