Thread: Quick Shock...
    Jun 2013
    Newcastle, Oklahoma
    508
    Quick Shock...
    pool store gave me 6 bags of it with my new pool. if I ever do need to use it, how much does a bag of Quick Shock raise FC? also, im assuming it has stabilizer in it too, how much CYA will a bag add?
    they also gave me some type of weed and grass killer in a tub? whats up with that?
    thanks!
    Partially buried Doughboy Desert Spring 16 x 32, sport pool, with 7 ft deep middle, 20,000 gallons, Hayward Powerflo Matrix 1.5 HP 2 speed pump, 250 lb sandfilter, 2 Doughboy skimmers and 2 returns. 2 cascade fountains.
    Taylor K-2006 kit. Zodiac Barracuda Ranger suction side cleaner.
    TFPC method and is crystal clear every day thanks to TFP!!!
    Re: Quick Shock...
    Sounds like there is no label. I'd guess that is dichlor so use the Pool Calculator, Effects of Adding Chemicals at the bottom to find the FC per bag. Weigh the bag or maybe it is one pound.
    Jun 2013
    Newcastle, Oklahoma
    508
    Re: Quick Shock...
    Quote Originally Posted by anonapersona View Post
    lol. nope, no label. just says quick shock. gotta love pool store.
    Isaac-1's Avatar
    SW Louisiana
    6,711
    Re: Quick Shock...
    If you know the pool store it came from ask for the MSDS sheet on it, this should tell you if it is dichlor or cal-hypo
