Thread: Hayward Superpump New Sea leaking
    Hi, I just rebuilt my Hayward superpump SP2615X20 with a Aladin GO KIT-3 because it had a slight seal leak. Pump bearings are tight and smooth.
    Pump ran great and dry for about 20 hours but now the leak is back. It is very slow dripping from rear of pump below motor. No air leaks etc. Thoughts. Thanks, Fred
    18' x 38' vinyl liner, 28k gallons, Hayward superpump SP2615X20, Hayward DE filter DE3620,variflow valve
    Charlie_R's Avatar
    May 2013
    Mexico, MO
    2,156
    Re: Hayward Superpump New Sea leaking
    Is the leak coming from the shaft seal or the case seal O-ring?
    Quote Originally Posted by Charlie_R View Post
    Leak is from shaft seal. Thanks
