Results 1 to 9 of 9
Thread: Outdoor Remote
    Cool Outdoor Remote
    Hello All,
    So I have an outdoor speaker system that feeds into a sonos system inside the house. I would like to have a simple remote control outside where I can mute or skip a song. The problem seems to be the distance and battery of most remotes. It needs to be durable enough to work in the daytime and be easy to use so others can use it. It needs to be weatherproof, waterproof, heatproof for the hot tub and have a good battery life (maybe solar with lithium battery). Does anyone have a recommendations for a weatherproof remote? I have phone apps, but the problem is the battery goes down quick. It would probably have to have a wifi or bluetooth connection, since IR wont work in the daytime. Thanks for your ideas.
    Brian
    Killer95Stang's Avatar
    Sunny SoCal
    591
    Re: Outdoor Remote
    Do you say you have an app that you use on your phone or tablet? If so, I use my phone to control the volume and shuffling of songs with my Galaxy S4, and have no issues with the battery life. I charge it every day so, it isn't an issue.
    Pool done!! (backyard = work in progress) 32' x 19' inground freeform with 7' spa, baja step w/ (2) bubblers, stonescapes mini pebble finish, rock waterfall feature, 12" raised bond beam, Intelliflo VS, Whisperflo feature pump, (3) 5G Color LED's, FNS + DE 60, 400K Master Temp, Easytouch 8 w/ remote, Intellichlor IC40, Vision Classic Ceramic Kamado smoker, Margaritaville DM1000!!! Party Coming Soon!!
    TF-100 Test Kit w/ Speedstir
    Re: Outdoor Remote
    Yes, there is an app on my phone. But the problem is I really don't want my phone around the pool for any reason. So I was thinking if there was some kind of outdoor remote control for the system then I wouldn't have to build anything.
    Feb 2012
    Winston Salem NC
    161
    Re: Outdoor Remote
    What kind of phone do you have? It may be a less expensive and easier alternative to use you phone with a waterproof case. I have a lifeproof on my iPhone 4S (old phone) and 5S. They both work well.... I even take them off the diving board!
    18x36 IG Vinyl. ~29k Gallons.
    Pentair CCP420 Cartridge Filter
    Pentair Inteli-flow VS Pump
    Hayward Goldline SWG
    Tigershark QC Robot
    Re: Outdoor Remote
    Ok, it was my birthday yesterday and I got a gift in the mail from an unknown sender. It answered my question. It was a waterproof smartwatch called the Pebble. There is an android and ios app called kronos that is a sonos remote. So now I am in the hottub and can change the volume, pause and skip songs. Awesome!
    Re: Outdoor Remote
    Something I have seen..
    Our neighbors actually have taken their older iPhones/smart phones and iPads with a waterproof case and just use those as quick remotes and even internet and texts. Controls lighting, sound, tv, automatic sun shades, even locks the front door or closes garage remotely in some cases.. Pretty cool. Wonder if it could make our favorite adult beverages.. Lol
    Their normal smartphone stays out of the way and they can just sit in the pool or spa and relax.
    When we get our pool and backyard laid out.. No doubt I will look to do similar.
    Low cost and high appeal and value option.
    Once the first neighbor did it, the others followed since they all had an older phone or tablet laying around.
    The wifi was extended.
    Oct 2013
    Oklahoma
    50
    Re: Outdoor Remote
    The smartwatch sounds pretty cool. No need to get up or out of the pool when u want to make a change since its always right there. Ill have to look into that. I imagine Apple has one coming out in the fall
    13000 gallon pool, SWG, DE Filter, 2 sheer descent waterfalls, built Jan 2014
    Oct 2013
    Oklahoma
    50
    Re: Outdoor Remote
    Texasbluestar. Does your Pebble need to be within a close distance of your phone to work. I assume it blue tooths to your phone instead of connecting directly to your wifi.
    Apr 2012
    Mason, Ohio
    119
    Re: Outdoor Remote
    Quote Originally Posted by Soonersalt View Post
    The Pebble does use Bluetooth. I lose connection on mine after around 30 feet - probably more if I was outside without any walls.
    34K gal IG, 37'x40' lagoon, vinyl, Pentair IntelliFlo VS Pump, 500# Hayward sand filter, Jandy SWG, Raypac heat pump, 4 deck jets, Hayward Super Pump + deck fountain, Dolphin Oasis Z5
