Thread: intex hose fitting
    intex hose fitting
    Guys I have question I have a 16th ultra from intex pool with salt generator and sand pump using the intex hoses my kids are wanting a fountain I seen where some of yall hard pipe and t off for a second return. I'm wanting to do the same thing but I don't wanna hard pipe my pumps is it possible to find some kinda fitting my be a barbed t fitting for my intext hoses and get another intex hose to connect to a fountain?
    mac.dblues's Avatar
    Jul 2013
    Arkadelphia, AR
    321
    Re: intex hose fitting
    The flexible part of the intex hoses are going to be hard to get to seal if you cut your hose to install a tee. I think I would take one of my hoses to a plumbing or hardware store and see if they have a tee and a PVC nipple that will fit in the end of the hose where it is smooth and will clamp properly. If so, I would buy a 14" sand filter interconnecting hose and 1.5m pump to pool hose. The 14" hose will reduce the amount of hosing you have laying around. I would attach it to the pump and put the tee down close to the ground. Don't forget to get the PVC shut off to connect to your fountain. Aeration raises pH and lowers water temp, so you may not want to run it all the time.
    Mac.Dblues and ProfessorDaisy's Lower Arkansas Pool Install
    Intex UltraFrame 20ft x 52in deep, 9,400 Gallons / Approx 78,500 lbs, Intex 1600 GPH, 14" sand filter, Hayward Dyna-Skim SP1091LX, Taylor K-2006, SpeedStir, Sample Sizer
    First Fill May 2014, Deck finished June 2014, Mods happening probably on a continuous basis. Stay tuned.....
    I did this, and it works great so far. I use a venturi skimmer most of the time, and a fountain when we want one, because the fitting is a standard thread size.
    http://www.rebeltechs.net/pages/pool/
    Wanda
    Intex 10x30 pop up pool, 1,018 gallons, Krystal clear model 603 filter pump, not installed yet.
