Thread: Draining pool
    Mar 2010
    Houston
    37
    Draining pool
    I have a spigot right above my pump, on the line between the pump and the filter. Can I use this to drain the pool? I need to lower my CYA.
    Thanks.
    Houston
    ~20,000 inground plaster pool
    1.5 HP Hayward
    Sand Filter
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    18,967
    Re: Draining pool
    Yes. That's why it's there.
    Be aware that if the main drain is not separately plumbed, you'll only be able to drain down to the skimmer, and then it will start sucking air and loseprime.
    Mar 2010
    Houston
    37
    Re: Draining pool
    Do I need to do anything on the simmer baskets so they don't suck air?
    Houston
    1.5 HP Hayward
    Sand Filter
    Richard320's Avatar
    Jan 2010
    18,967
    Re: Draining pool
    If you have valves to shut off the skimmers and open the main drain, that's what you want to do. If you don't have a way to draw water only from the main drain, your best bet is to rent a submersible pump.
    Mar 2010
    Houston
    37
    Re: Draining pool
    Thanks. My only values are after the filter so I guess I will be using a sump pump.
