Results 1 to 20 of 20
Thread: Can't Keep Chlorine ... Done with Leslies
    May 2014
    Las Vegas NV
    45
    Hello,
    All of a sudden I can't keep the chlorine levels above 0. I've been to Leslies and have shocked week after week, but after a few days the chlorine level is back to 0 even with 6 tablets in pool (most I ever used last year was 3 in July/Aug). Thank god I found this site! I have a TH-100 test kit on order and, for now, will post the only results I have (from Leslies this morning). Pool water is crystal clear and there is a white film on goggles after swimming. On my way to get some liquid chlorine and am ready for SLAM procedures, but won't have my kit until later in the week. Am I on the right track? PLEASE HELP! Any advice would be greatly appreciated. Thanks in advance!
    FAC = 0
    CYA = 90
    TA = 100
    PH = 7.6 (I tested at 7.2)
    TDS = 1400
    Pho = 0
    9700 gallon outdoor in-ground 11x26' plaster pool; Pentair Intelliflo Variable Speed pump; Pentair Clean and Clear Plus cartridge filter;
    Pentair MasterTemp 400 natural gas heater; 2-wheel "The Pool Cleaner"
    Oct 2013
    Chapin, SC
    1,141
    Re: Can't Keep Chlorine ... Done with Leslies
    Congrats on dumping leslies and cya up in the form of tabs and shock just be aware, leslies was telling me my cya was 40 for months until I got my own test kit and found it to be over 340. 40,000 gallons later, I finally got it down to 50. You might just find out yours is considerably higher than what leslies is telling you. Hope not, but -----
    Pool size: 24000gal inground Vinyl-Taylor k-2006 and k-1766 test kits and-speed stir
    Intermatic P1353ME digital timer w/freeze sensor
    CircuPool Si-45 SWCG System
    Polaris 280 vacuum/Polaris PB4-60 boost pump
    Pentair IntelliFlo VS 3hp Pump--Pentair sand filter
    May 2014
    Las Vegas NV
    45
    According to my test strips the CYA is more like 150. If it is more like 150 I'm assuming draining the pool would be the first step? Should I just wait until I get my test kit before I do anything?
    Oct 2013
    Chapin, SC
    1,141
    If it's that high or higher you're probably safe not waiting and do a 50-75% replacement now. Make sure you close the valves to your skimmers if you have a separate main bottom drain so you're not sucking air. Unfortunately I didn't do that and irreparably froze my cleaner boost pump, and was probably lucky the main drain provided enough water flow to not do the same to my filter pump.
    Mod Squad zea3's Avatar
    Jul 2009
    Houston, Texas
    9,377
    You will probably need to do several cycles of partial drain and refill to get the CYA at a manageable level. You could go ahead and start the first drain/refill cycle and while you are waiting on your test kit to arrive, read up on our pool school articles. ABCs of pool water chemistry is a good place to start.
    Love TFP? Become a
    TFP Supporter!
    May 2014
    Las Vegas NV
    45
    Thanks for all the advice. With the temps out here in Vegas approaching 100% is there anything I need to be aware of like keeping the plaster wet?
    Jul 2009
    Houston, Texas
    9,377
    As long as you are not leaving it dry for days at a time it should be ok.
    Love TFP? Become a
    TFP Supporter!
    Divin Dave's Avatar
    Oct 2013
    Longview, Texas
    5,003
    If you like, you can drain from the bottom of the deep end and hang a water hose over the shallow end and refill at the same time. This would lessen any likelyhood of a plaster problem.
    Sounds like you are finally fed up with being 'pool stored' like tons of other folks here.
    Congrats are in order for getting your own reliable test kit on order and are taking control of your pool (and your wallet)!
    You wont be sorry.
    I look forward to seeing your sparkling clear pool with minimal expense and time spent keeping it that way from now on!
    Divin Dave,
    May 2014
    Las Vegas NV
    45
    May be a stupid question, but I'll ask anyways. I forgot to mention earlier that I have a lot of construction going on around my house as opposed to last year. Would that have anything to do with the increased chlorine usage?
    Isaac-1's Avatar
    SW Louisiana
    6,711
    It is possible that some form of contamination is causing chlorine demand, but either way it looks like your CYA is too high, or maybe way too high
    May 2014
    Las Vegas NV
    45
    Decided to Drain ... Wait or do now?
    Merged by moderator to keep your story together. jblizzle
    Hello,
    After posting a message the other day I've decided to drain/refill my pool, but my new testing kit wont arrive until next Monday. Should I wait until the kit arrives to do so or will test strips suffice until the test kit arrives? Also, with the temps reaching 100 here in Vegas should I be adding chlorine or anything while the pool is filling? It should take under 2 days to drain/refill. Any advice is greatly appreciated. Thanks in advance.
    38,251
    Well, at this point you do not know how much water you need to drain to get the CYA and CH down. Also given the heat, it may not be a good idea to have the plaster exposed without water for very long. You could certainly do a partial drain and fill and then test when the kit comes in.
    May 2014
    Las Vegas NV
    45
    OK. Leslies is telling me my CYA is 90 but my test strips are saying more like 150.
    38,251
    So replacing 50% will certainly not hurt anything ... although you may learn latter that you need to do that again.
    Also, depending on your CH, you may also want to replace more water.
    Oct 2013
    Chapin, SC
    1,141
    Hehehe, Leslie's was telling me mine was 40 for months until I got my own test kit did the dilution technique 3 times to get a reading below 90. It was 340!!! Whoops, already told this story please delete.
    May 2014
    Las Vegas NV
    45
    I really appreciate everyones help. Thanks alot! Looks like my test kit will be here by end of day tomorrow (earlier than expected). When I get the kit I'm assuming I should test and post my numbers before doing anything?
    I already told the same story too. Sorry about that!
    38,251
    If you are comfortable, you do not need our approval to make any changes. But if you want help coming up with a path forward, post up the results
    May 2014
    Las Vegas NV
    45
    Drained my pool about 70% and refilled. Finally got my test kit and here are my numbers. Please advise on TA and CH. Was planning on SLAMing tonight unless advised otherwise.
    PH = 7.5
    CYA = 40
    FC = 5
    CC = 0
    CH = 475
    TA = 160
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    18,967
    Quote Originally Posted by badgerwooz View Post
    PH = 7.5
    CYA = 40
    FC = 5
    CC = 0
    CH = 475
    TA = 160
    Go!
    You can fix TA later. Kill that algae! Kill it dead!
  20. Back To Top    #20
    38,251
    SLAM away!
    Note to lower the pH first.
