Thread: Difference between timer settings and Speed settings
    azsunshine2014's Avatar
    May 2014
    Scottsdale, AZ
    14
    I searched but couldn't find what I was looking for.
    I do not understand the difference between the timer settings and Speed settings. Both have speed and length of time to operate.
    Here are my settings:
    Timer:
    Low: 1400 10pm to 3am 7D
    Cleaning: 2350 3am to 7am 7D
    Timer 3: 1950 9:30 to 5:30pm Saturday. This is only used when we're in the pool We like circulating water when using the pool and it's the only way the spillway from the spa to the pool works.
    Speed:
    Speed 1 1400 5 hours
    Speed 2 2350 4 hours
    Speed 3 1950 8 hours (only as desired)
    Speed 4 (Backwash) 2800 30 minutes
    We live in Scottsdale,AZ where it's really hot. We run the pump at night and for a lot longer than less hot areas.
    What do I look at when setting the pump to run? The timer settings? The speed settings? Which is default?
    The owner's manual is one of the worst manuals I've read. It give what each thing is but not how or why or which to use.
    Thanks!
    ***Original owners of 18 year old 8500 gallon inground Pebbletec pool/spa with spillway into pool
    ***Saltwater system ***Hayward sand filter
    ***PebbleTec completely replaced April 2014 Hayward EcoStar Variable speed pump (IS3401VSP) installed May 2014 New sand - May 2014
    May 2014
    Scottsdale, AZ
    14
    Re: Difference between timer settings and Speed settings
    After further research, my guess is that the timer settings are for the nightly cleaning. The blue speed buttons are manual settings for when we want to run the pump during the day. But, I really don't know that. And based on the tech that installed it, my guess doesn't make sense.
    May 2014
    Tuscaloosa, Alabama
    9
    Quote Originally Posted by azsunshine2014 View Post
    Thanks!
    What piece of equipment is this you're referring to? Model number, etc.
    22,500 gallon in-ground. 2 skimmers plus deep-end intake. Hayward sand filter. Polaris with booster pump.
    Jan 2013
    Houston, TX
    1,079
    Looks like a variable speed pump. The speed settings determines how hard the water is pushed, the timer is how long it runs. The 4 digit number is the rpm of the pump ( speed)
    What kind of automation system do you have?
    TFP Moderator Chris V. ~16K Pool & Spa, 48NSF DE, IG Plaster Circa 2000, Intermatic PE653, Challenger pump with a 2 speed B2984, 20gal stenner chlorine injection, Houston, TX
    One cannot follow Islam and Christianity at the same time, nor can one follow pool store methods and TFP at the same time.
    Pool School -- Pool Math -- TF-Test Kit
    May 2014
    Scottsdale, AZ
    14
    Well, duh, that would help! It's in my head but didn't make it to the written page.
    Hayward EcoStar IS3401VSP
    Sorry!
    If the speed settings are for how hard the water is pushed, then why is there a setting for # of hours to run in each speed setting?
    If the timer is for how long it runs, they why is there a setting for speed for each timer setting?
    That's where it doesn't make sense.
    They are trying to make it "easy" so you can program a schedule regardless of which way you get to the list. Though I agree that all they have done is make it more confusing.
    When it comes down to it, there are four timers, each of which can be given a time to run and a speed to run at. You are just looking at them in different ways.
