Thread: Skimmer shut off valves
    AV8TOR's Avatar
    Dec 2008
    Fort Worth TX
    211
    Are these ball valves a suitable replacement for my two skimmers and center drain adjustment? Or is it better to pay $73 more to get the Neverlube's? I am going to replace my main pump and all plumbing is why I ask.
    http://www.homedepot.com/p/Homewerks...0E8B/202369989
    http://www.poolsupplyworld.com/Jandy...-Seal/4716.htm
    16,000 gal IG Double Roman Plaster Pool (16yrs - plaster redone 2014)
    Pentair FNS-48 DE filter with WhisperFlo 2HP single speed pump
    Polaris 280 robot
    BBB all the way and tested with a TF100 kit
    Pool Calc user
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    19,065
    Re: Skimmer shut off valves
    No. Use the search box for "ball valve" and you'll find page after page of threads where people complain of the handles breaking, air leaks, valves that won't turn anymore, you name it. Spend the extra and be done with it.
    AV8TOR's Avatar
    Dec 2008
    Fort Worth TX
    211
    Thanks, I was pretty sure but thought I would ask
    Polaris 280 robot
    Pool Calc user
    Divin Dave's Avatar
    Oct 2013
    Longview, Texas
    5,013
    that 73 dollars sounds like a pool store price. You can get 2 inch never lube Jandys for 40ish dollars every day all day long. Google Amazon.
    Divin Dave,
