Results 1 to 7 of 7
Thread: Losing return pressure after a couple of hours
    Jun 2012
    Smithtown, NY (Long Island)
    65
    I have about a 30,000 gallon pool with a Hayward Pump and DE Filter. The pump is 2.5HP and 230 Volts. This is my third year at my new house and this pool and I've noticed that the returns always lose pressure after about 4 hours of runtime. I don't notice any leaks around the pumping station. How do I know when it is time to purchase a pump? Is there anything I can spot check before settling on purchasing a new pump?
    ~30,000 Gallon Free Form Pool; IG; Vinyl; DE Filter; Installed 2005
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    19,074
    Re: Losing return pressure after a couple of hours
    You mean to say the flow out the returns decreases?
    What does the pressure gauge on the filter say?
    It just sounds to me like the filter is getting dirty and needs backwashing and fresh DE. When you shut it off, whatever stuff is stuck to the grids from pressure slumps off and settles on the bottom. When you restart, the lighter stuff rises and recoats the filter and it starts accumulating again.
    Jun 2012
    65
    Yes, the flow of the return decreases. i just opened the pool today and i thoroughly cleaned the filter last fall after i closed and added fresh DE today. Do you think after the first three hours of the year it would get so dirty and stop? My pool was a bit swampy but this has been a problem since I had the pool but not as bad as today.
    I am going to turn the pump back on so i will check the pressure.
    Richard320's Avatar
    Jan 2010
    19,074
    Quote Originally Posted by pisstol27 View Post
    Absolutely. A sludgy pool will load up a DE filter in a hurry! It just shows how efficient that filter is.
    Jun 2012
    65
    OK, just got back from turning the pump back on and noticed no water was flowing back to the filter so i opened the pump basket and water level dropped and there was a sucking sound. i tried adding water (both with pump on and off) and once the pump is on the water just gets sucked down. There pressure gauge on the filter stays at zero.
    Richard320's Avatar
    Jan 2010
    19,074
    You won't see any pressure - clean filter or dirty - if you empty the pump basket. the garden hose can't keep up with the demand from your pump. The gurgling when you opened the basket is normal.
    Put everything back together and open the air bleed on top of the filter and then turn the pump on. It might take 30 seconds, but you should start hearing the pump change pitch and then air and eventually water will come out the bleed.
    If it doesn't, then you have problems on the suction side as well.
    Jun 2012
    65
    Thanks, i filled basket with water and opened the air bleed and like you said water eventually started coming out so i closed it. the pressure is at 20 so i will monitor it and backwash when it gets to 25 or 30.
