Results 1 to 7 of 7
Thread: Help! Wrinkles on bottom of new liner - what should I do??
    Mar 2014
    Indiana
    28
    We are installing our liner now and there are wrinkles on the bottom. We have about 1/4" water in right now, so I think there is still time to fix. We tried pulling them out and tried the shop vac, but can't get them out. Any suggestions?
    27' Radiant Metric AGP ~17,300 gallons
    Pentair Clean & Clear 150 sf Cartridge Filter
    1 1/2 HP Dual Speed OptiFlo Pump
    Louisiana
    127
    Re: Help! Wrinkles on bottom of new liner - what should I do??
    Did you let liner sit in sun for a bit to heat up? When I did mine I just got on hands and knees and started pushing them towards the coves. It does take time but go slow and make sure you get all before putting too much water.
    Also the shop vac is usually done before adding water to see if Liner is good in place and while filling.
    27' Radiant Metric, 17,100 gallons
    Pentair Dynamo 1.5hp 220v
    Circupool RJ45, Sand Filter, Borates
    Dolphin DX6 Robotic cleaner
    TF 100 Kit
    30,405
    As kpromero says, the shop vac is done prior to water fill and it's sole purpose is to hold the liner tight against the pool walls so the wrinkles are gone BEFORE you put in any water.
    I would get the water out of the pool and start over. If not, I think those wrinkles will haunt you from an aesthetic standpoint.
    Divin Dave's Avatar
    Oct 2013
    Longview, Texas
    5,003
    agreed with all above. It might help to use a broom and use it like a squeege to help push the wrinkles out. Some folks have had success with a toilet plunger to grab the liner and pull them out too.
    Divin Dave,
    Mar 2014
    Indiana
    28
    Thanks, everyone! We got in on our hand and knees and pushed the wrinkles to the cove, also used the broom and in the end let the kids slide around and within 45 minutes we were wrinkle free!
    laceygirl's Avatar
    Dec 2013
    Canberra Australia
    1,273
    That's great news...
    Intex Rectangle 18 x 9 x 52', 4544 gallon (18000 litres), 0.75 hp pool pump, 100 sqft Zodiac Titan Cartridge Filter - 40mm, Stenner Peristaltic Pump chlorine injection system, Intex Over The Wall Skimmer, Intex Fittings with 40mm plumbing Lil Patch Of Heaven. Build/Construction http://www.troublefreepool.com/threa...lice-of-heaven
    Louisiana
    127
    Good to hear ashpool. Glad you got them worked out.
    TF 100 Kit
