Thread: Impeller Seal Question...
    Mar 2013
    CT
    353
    Can an improperly replaced impeller seal cause air in the system? I have lots of air bubbles visible in my leaf strainer "window" this year. I have to bleed off the air every half hour. Local pool store replaced the seal on my pump over the Winter and I'm wondering if the two are related.
    Thanks!
    16 x 32 In-Ground vinyl, 21,000 Gallons, Hayward Cartridge Filter, Hayward Tiger Shark robotic cleaner, Taylor K-2006 Test Kit
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    19,073
    Re: Impeller Seal Question...
    It's possible, but unlikely. Do you see any water dripping? Any squirts the instant the pump shuts off?
    More likely would be the seal between the motor plate and the pump housing, or the usual suspects - pump strainer gasket, pump drain plugs, stuck wier in the skimmer, low water level.
    Mar 2013
    CT
    353
    Problem solved. It was the union screwed into the front of the pump. Loaded the threads up w thread sealant and all is good tp go.
    Sent via Tapatalk
