Thread: Need help cleaning filter
    AV8TOR's Avatar
    Dec 2008
    Fort Worth TX
    211
    I have an Aquatech FNS-48 DE filter and as I took over this home I never had equipment manuals. Am I supposed to be able to lift this assembly out of my filter? Or do I have to remove the two screw and remove the black plastic top cover and remove all plates individually?I have been just hosing this clean as it sits and collecting the junk from the drain. Thanks in advance
    16,000 gal IG Double Roman Plaster Pool (16yrs - plaster redone 2014)
    Pentair FNS-48 DE filter with WhisperFlo 2HP single speed pump
    Polaris 280 robot
    BBB all the way and tested with a TF100 kit
    Pool Calc user
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    19,055
    Re: Need help cleaning filter
    I don't know how that comes apart, but I clean mine the way you've been doing yours. Unless you think you need an acid wash, I see no reason to remove them.
