Thread: Folding down old liner for bed.
    Onslow's Avatar
    Jul 2010
    Kentucky
    140
    I've had a couple of pool contractors look at doing the work for replacing our liner. One stated that he wanted to cut the walls of the old one into vertical strips to lay down flat, keeping it all as a bed for the new liner. It seems my wrinkly old liner would just make the bottom of a new one worse. Is this a common practice?
    Thanks.
    * 18' x 33' - 48" oval AGP - new liner Summer 2014
    * Hayward Pro Series S210T Top Mount Sand Filter
    * Hayward Power-Flo Matrix 1 1/2 hp Pump Model SP5615
    (equipment on posts prior to summer 2014) Hayward PowerFlo 1 hp pump - Jacuzzi "Tidewater" 190L, sand filter
    30,432
    Re: Folding down old liner for bed.
    Never heard of it before. Not saying it won't work, but I have never heard of it.
    (Please change the location in your profile to reflect city and town in which you live.)
    Casey's Avatar
    SW PA
    10,461
    As Dave mentioned on both points, never heard of it and please change the location.
    As far as using the old liner on bottom, I wouldn't do it because it'd probably cause trouble smoothing the bottom out. If the liner comes up or folds over while the new one is installed, you won't know til you have water = too late.
    Jun 2013
    Newcastle, Oklahoma
    508
    sounds like a terrible way to do a liner change to me, i would make them remove it completely. in fact, id find a new liner guy, this one sounds like trouble.
    Last edited by Casey; 05-28-2014 at 11:36 AM. Reason: Going around net nanny to cuss
    Partially buried Doughboy Desert Spring 16 x 32, sport pool, with 7 ft deep middle, 20,000 gallons, Hayward Powerflo Matrix 1.5 HP 2 speed pump, 250 lb sandfilter, 2 Doughboy skimmers and 2 returns. 2 cascade fountains.
    Taylor K-2006 kit. Zodiac Barracuda Ranger suction side cleaner.
    TFPC method and is crystal clear every day thanks to TFP!!!
    laceygirl's Avatar
    Dec 2013
    Canberra Australia
    1,273
    Yup I'd be asking other guys in your area...
    Intex Rectangle 18 x 9 x 52', 4544 gallon (18000 litres), 0.75 hp pool pump, 100 sqft Zodiac Titan Cartridge Filter - 40mm, Stenner Peristaltic Pump chlorine injection system, Intex Over The Wall Skimmer, Intex Fittings with 40mm plumbing Lil Patch Of Heaven. Build/Construction http://www.troublefreepool.com/threa...lice-of-heaven
    Onslow's Avatar
    Jul 2010
    Kentucky
    140
    I tried to ask about the wrinkle factor - floor is flattened with "vermiculite"?
