Results 1 to 10 of 10
Thread: Fell asleep with sump on....ugh
    Kids were splashing a lot of water out last night so my intention was to lower the water by 2", um yeah then I fell asleep. Party's in 6 hours, it's down 14", any chance it can refill in time? Existing water us 74 hose water is 59, I'm not even sure it'll be warm enough. Pump ran dry for several hours as well, it was still working when I shut it off though.
    24' AGP, 54" - 13,300 Gallons at 47".
    AquaRay Cleaner
    Hayward Swimpro Voyager Filter/2 Speed 2 HP Pump
    Re: Fell asleep with sump on....ugh
    You should be able to raise the water that much, though it is going to be close. If possible run more than one garden hose out to the pool, more hoses means a quicker fill.
    As long as you have a very warm sunny day cool water is kind of nice.
    AimeeH's Avatar
    Apr 2012
    Columbia SC
    1,867
    Reminds me of when "somebody" left the filter set to waste on ours last summer overnight. Pump wasn't on but it had drained down to about a foot of water left in the shallow end. I feel your pain. Of course ours was like an 8-10 hour fill I think. I would think you can get that up pretty quickly.
    18*36*23 true "L" vinyl IG 29,000 gallons. SWG. TF-100 test kit.
    http://tftestkits.net/splash-page.html
    Divin Dave's Avatar
    Oct 2013
    Longview, Texas
    5,003
    oops!
    Divin Dave,
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    18,967
    I forgot the hose in the pool when I was filling once. That was enough.
    Now as soon as I drop it in, I go set the kitchen timer on the stove for half an hour so I don't forget.
    Once burned is twice learned!
    Have you considered installing an overflow by drilling a hole in the skimmer, above normal and below the rim, and installing a fitting and hose to take it far way from the pool base?
    Charlie_R's Avatar
    May 2013
    Mexico, MO
    2,156
    Seem like every time I have to add a few inches of water to my pool, I get called away, and end up overfilling. That's why I keep a bottle of CYA on hand.........
    Casey's Avatar
    SW PA
    10,423
    Oh my goodness!
    I have now lol. Seems like a great way to "set it and forget it".
    AquaRay Cleaner
    I had all my chemistry dialed in too...
    AquaRay Cleaner
    Not sure how I didn't empty the pool, pumps rated at 25 gpm
    AquaRay Cleaner
