Thread: My first water testing
    May 2014
    Northern New Jersey
    4
    Hello
    My pool is 7 days old. I did my first test today with a Taylor k-2006. Here are the results.
    FC 1.2
    CC 0.2
    PH 8
    TA 220
    CH 170
    CYA none
    I have a salt system but can't start it for 30 days so PB is using 2 chlorine tablets in each skimmer. I wonder if I need a little more. TA is very high but I'm reluctant to play with it while PB is responsible for water and plaster start-up. Any suggestions would be great.
    Thanks
    26K gal Free Form, IG Wet Edge Primera Stone Midnight Breeze, 100 sf Sun Shelf with 2 Bubblers, Jandy DEV filter w/2 HP Flow Pro pump, Jandy Salt Aqua Pure System, 2 ft reaised spa with 2 HP booster pump for waterfall, iAqualink controls
    Re: My first water testing
    Typically you want one tablet for every 10,000 gallons of water, so 2.6 tablets in your situation. Since fractional tablets are too much trouble, overlapping the new pair with the old pair will give you about the same effect. In any case, their two tablets approach is reasonable, if perhaps just slightly low.
    The PH and TA numbers are typical for a bicarb startup. If they are doing a bicarb startup you don't want to mess with PH or TA.
