Thread: Losing pressure
    Losing pressure
    Happy Memorial day!
    I've researched a bit and didn't see anything that quite answered my question.
    After 4 days or so of runtime, the pressure on my sand filter drops from 20 psi to about 15. I clean the baskets daily (including the pump basket ) and it doesn't seem to help. However, after a backwash the pressure returns to 20. Could it be a bad guage? I used to work in an air force metrology lab and guages would surely fail... but in this case the repeatability of my symptoms doesn't seem to jive with a bad guage.
    Channeling perhaps?
    Thoughts are appreciated!
    20 x 40 28k gallon Salt Water Vinyl IGP, Hayward pump and Sand filter
    Apr 2013
    North OKC Area
    300
    Re: Losing pressure
    Channeling does sound like a possibility, but I would replace the gauge first because they are cheap and less likely to cause another issue than deep cleaning. This is assuming you're not getting air in the returns.
    Re: Losing pressure
    No air in the returns as far as I can tell. Thanks for the reply!
