Results 1 to 13 of 13
Thread: Just Signed Up, Got the Crazy looks at Costco Yesterday!
    Scice77's Avatar
    May 2014
    Central Jersey
    17
    Hey Everyone, I'm just getting on board now.
    Got my K2006 test kit this week, took the cover off Saturday and got my first readings yesterday. My free chlorine was at 0.6 and my CYA was at 80. So my calculations were to add 11 (121 Ounce) Costco size jugs of Clorox to shock to FC 31 (sometimes the 121 ounce size shows up on the Pool Calculator drop down, sometimes not).
    I'd like to start using bleach as my exclusive source of Chlorine. I don't want to use pucks anymore. Do my calculations seem correct, I just want to make sure.
    I sure did get some looks at Costco with 6 cases of Clorox and the expected "dead body cleanup" joke from the Cashier. I have 5 bags of Baking Soda on standby as well as 5 boxes of Borax.
    I have gotten so much great info from this site already, I figured it was time to sign up and go full BBB method. I plan on checking the TA and pH today, I should add the baking soda first to raise both before the Borax, right? Do I seem to be on the right track? Thanks in advance.
    33K gal. Super Steel Grecian IG (built 1994), Vinyl Liner (Replaced 2013), Jacuzzi EW 75 DE Filter (Original 1994), 1 HP Heyward Super II Pump, TF-100 Test Kit, Polaris 380 Cleaner
    Mod Squad JohnT's Avatar
    SW Indiana
    9,199
    Re: Just Signed Up, Got the Crazy looks at Costco Yesterday!
    Welcome to TFP!
    Use PoolMath to get the 121oz jugs. The Pool Calculator hasn't been updated.
    16 jugs should have gotten you to 31ppm FC, but if you have algae, most of the chlorine was probably gone within a few hours. You need to keep testing frequently to keep up with chlorine consumption when you have algae.
    Baking soda and borax aren't always needed. Only if test results indicate low TA for baking soda, and only if you need to raise pH without raising TA for borax.
    Run your full suite of tests and post the results and we'll talk you through it.
    Jan 2012
    'burbs of Augusta, Georgia
    7,364
    Hey there Gamecock fan... I'd suggest posting a full set of test results first before you add anything. Have you considered a little water exchange to bring that CYA down a bit?
    Butterfly's Avatar
    South Carolina
    10,045
    Hi there Carolina Gamecock and welcome to TFP
    What are you doing so far away?!
    Yep, we'd like to see the test results and a pic of the pool would be great, too!
    You're done SLAMing when:
    Scice77's Avatar
    May 2014
    Central Jersey
    17
    Thanks for the welcome and quick replies. Well after adding the Clorox last night, I just took a reading this morning.
    My FC was 38 (I was shooting for 31) after adding the 11 --121 oz bottles of clorox.
    My PH was at least 8 (indicator on kit was maxed out).
    My TA was over 700 (is that possible) I just kept adding drops and the tube turned yellow from green, but never red. I stopped at this figuring the shock last night shot that number up.
    I'm not sure about draining yet to lower CYA, I figure I'll consider that once I get through with all the start up backwashing and then get a reading to see where I stand. Pool is still pretty cool, so I won't be using it for a couple weeks, therefor I'm in no rush. Just want to get it right. Put a new liner in last fall, and I really want to keep it in good shape.
    Are these somewhat normal after the shock last night?
    Pool is clear, no visible algae. Backwashed 3 times in the past 24 hours, but this is normal for me at opening as I have a mesh center in my safety cover.
    I think I'll take more readings tonight after the sun hits it all day here in Jersey (supposed to be mid 80's today). I'll try to get a pic up with my readings post later.
    thanks again
    SW Indiana
    9,199
    Both your pH test and TA test are interfered with by high chlorine levels. Don't try to adjust any of that stuff while you have FC levels over 10.
    Scice77's Avatar
    May 2014
    Central Jersey
    17
    As far as the Avatar goes, went to Carolina for school, moved north for work, hope to return to retire. Still make it down for games occasionally. It's an addiction now.....
    Isaac-1's Avatar
    SW Louisiana
    6,711
    Chlorine levels over 10 through off the pH test, that is why we suggest correcting pH prior to starting the SLAM process
    Ike
    Divin Dave's Avatar
    Oct 2013
    Longview, Texas
    5,005
    Also when your TA turned from Green (or Blue) to yellow, thats when you should have stopped adding drops.
    The ultra high FC has some effect on the test turning red.
    Like the others said, no need to really test it now anyhow. Finish up the SLAM and then I bet ya get a much better test result on the TA
    Divin Dave,
    Scice77's Avatar
    May 2014
    Central Jersey
    17
    As yippeeskipee suggested, I agreed i should switch out some water. First I vacuumed to waste, then pumped it out. Took about 1/4 out, it's refilling now. Lets see how that effects the CYA. As much as I enjoy being looked at as a serial killer when I shop clorox in bulk, I'd rather use less. Post results when I can. Thanks everyone for the help so far.
    Scice77's Avatar
    May 2014
    Central Jersey
    17
    Good Morning everyone. Well I switched out some water yesterday and let the filter do it's thing overnight. Just to recap, my CYA was 80 Sunday morning and my FC was 38 (after adding 11 jugs of bleach to increase from .6). I took roughly 25% of the water out and now the CYA is at 70 (any drop is better I guess) and my FC is 26. I tried testing my PH and TA yesterday, but was told not to bother until my FC was below 10. The water is still clear (had no algae at opening on Saturday). Am I on track? Any suggestions on what to do next (gonna try to wait a week to switch out any more water). I added the pic I promised also. Thanks in advance.20140527_102951.jpg
    Oct 2013
    Chapin, SC
    1,141
    The cya results are off just as little bit from what would be expected. Could be you were off just a little bit on your drain estimate. When I had my problem last year, I would read my water meter before starting the refill and when completed. X5 OUCH!!!! Just finish up the replacement and you'll be fine! Btw, my pool was as sparkling blue and had a fc of 5 when I started the process. I kept on wondering when I was going to ever see the black dot. Then I finally found the dilution technique that opened up my eyes to the reality I needed to drain and drain and drain and drain and drain!
    Pool size: 24000gal inground Vinyl-Taylor k-2006 and k-1766 test kits and-speed stir
    Intermatic P1353ME digital timer w/freeze sensor
    CircuPool Si-45 SWCG System
    Polaris 280 vacuum/Polaris PB4-60 boost pump
    Pentair IntelliFlo VS 3hp Pump--Pentair sand filter
    Isaac-1's Avatar
    SW Louisiana
    6,711
    If you have no visible signs of algae, the water is clear, with 1ppm or less FC overnight chlorine loss, and have .5ppm CC's or less. There is no reason to continue with SLAM.
