Results 1 to 9 of 9
Thread: Now I have a question about timers
    May 2014
    Monroe, Louisiana
    32
    Since we've lived here, our pool has been "on" non-stop. In doing some research on this site, though, it appears that isn't necessary? When I had a pool service come out initially, they said turning it off and on through the day might save a few bucks in electricity each month, but that was it. Frankly, I'm not even sure if we have an auto timer. Is it really worth it?
    Smykowski's Avatar
    Sep 2011
    3,065
    Re: Now I have a question about timers
    Running the pump 24/7 is probably overkill. Every pool is different, but most seem to only need 4-10 hours per day.
    Whether or not its "worth it" to put in a timer depends on how much it will cost to install it, your electric rates, etc.
    Sep 2013
    DFW Metroplex
    119
    How big is your pool? There are lot of factors to consider on how long the pool pump needs to run, Do you have a single speed pump or variable speed pump, two speed and VS pumps are energy efficient. In my case i run my pump only 10 hours daily and I don't want to run it for 24 hours (my pool pump is oversized unnecessarily and its a energy monger). I have simple Intermatic timer with freeze protection thermostat, it takes care of two things
    1. Automatically on and off my pump based on my configuration.
    2. During winter, I configured to start and run the pump if temperature falls below 37 F
    This basic automation is worth it for me.
    Please post your pool specification in the signature so that experts from this forum can give you a specific recommendation.
    13K gal, IG, Gunite pool with raised spa water spill over to pool, built on 2005
    1.5 HP Hayward MaxFlo VS - June 2014
    DE Filter Model # DE6020
    Added Borates on Jun 2014
    Isaac-1's Avatar
    SW Louisiana
    6,711
    It is worth it if saving a few hundred dollars per year is worth it to you (exact amount depends on size of the pool pump, electric rates, etc.)
    Apr 2013
    Suburbs of Chicago
    76
    I would definitely thinking about installing a timer. At first I was turning my pump on before I left for work then off after I would get home...wasting a lot of electric. I then calculated the run time with the gpm and feet of head to find out that 4 hours of run time will turn through the water. Just to be safe I have a timer that will run 3 hours in the a.m and 3 hours in the p.m and I can see the difference on com ed bill.
    Fiberglass/Concrete IG
    Pool Size: 16500 gallons
    Filter: Hayward S244T Pro Series Top-Mount Sand Filter
    Pump: Hayward 1 HP Super Pump
    Divin Dave's Avatar
    Oct 2013
    Longview, Texas
    5,025
    Not to mention the wear and tear on the pump itself. Determining how much run time you actually need and installing a timer vs running 24/7 could easily extend the life of your pump motor significantly.
    Running 24/7 could be expensive on the electric bill, but having to replace the pump simply because it wore out in a relatively short period of time is a double whammy.
    Divin Dave,
    May 2014
    Monroe, Louisiana
    32
    Ok, I added a signature but the sad truth is, that's all I know. I need to get back and inspect things more carefully when I have alone time (I have a three year old who I can't escape from ). There might even be a timer back there for all I know. I've been able to maintain chemistry pretty well thus far but would really like to know more about how the whole thing works.
    NE Louisiana
    25k gallon IG 16x30 vinyl liner pool
    Hayward Super Pump 1.5HP
    Intermatic timer, ~8hr/day
    Sand filter
    Apr 2014
    Kentucky
    3
    Quote Originally Posted by Divin Dave View Post
    I read that a lot on this site, but the hardest conditions on the motor during runtime is startup...It's the same reason you never burn out light bulbs except when you turn them on. Turning the pump on and off saves on energy and probably the pump seals, but it's harder on the motor due to current inrush. I don't have an opinion on which is right or wrong (I run mine all the time), but wanted to clear this up a bit.
    mas985's Avatar
    Pleasanton, CA
    11,743
    For a centrifugal pump, there isn't much of a "large" current in-rush than say an AC compressor which is huge. In fact, the current ramps up with the motor RPM because the starting load is very close to 0. Pump torque is proportional to the RPM of the impeller. So at start there is virtually no load on the impeller. As the motor spins up, the load and current increase but again, the pump does not have full load until the motor is at full RPM and the amps never exceed that at full RPM. So I don't think there is much "wear and tear" on the motor due to cycling. However, for motors with a centrifugal switch, there is more wear on the switch so that might wear out faster but it can also be maintained.
    Mark
