Thread: Does robot clean steps?
    Divin Dave's Avatar
    Oct 2013
    Longview, Texas
    5,025
    Well now, check this out!
    He will definitely clean the bottom one but he runs into problems getting to the middle step.
    Ha! I have seen this little dude on the step a few times now but never sideways! Just thoght it was cool
    Divin Dave,
    Patrick_B's Avatar
    Jun 2011
    Midland TX
    14,998
    Re: Does robot clean steps?
    Hey that's cool, never saw mine do that.
    My Dolphin M5 will make it up to the second step and try for the top when he has in his spring carts, and ballasts out. Otherwise, he gets the bottom step just a little. For what he does, I can't complain at all and am amazed every day how much help he is. I've not hooked up my vacuum hose since he arrived. Not sure when I will either. Also never seen him get stuck where he needed help getting out either. He just turns or backs up, then off to work again.
    Essential Links:
