Results 1 to 8 of 8
Thread: How much bleach in my pool?
    May 2014
    Springfield, IL
    5
    Have a very small intex 12'x30" vinyl pool that's 1,400 gallons. Have my ph down to 7.3-7.4 but my total chlorine seems to be at about 1 and won't budge. I'm using 1" slow dissolving tablets and they don't seem to work so I'm going to switch to bleach. How much bleach do I need to get up to the recommended level of total chlorine for my pool? Just want to make sure I'm keeping my pool sanitized good enough.
    Intex 12'x30", 1,400 gallons, Krystal clear 540GPH pump
    Charlie_R's Avatar
    May 2013
    Mexico, MO
    2,156
    Re: How much bleach in my pool?
    You can check in PoolMath, linked on the top bar on every page. Put in your pool's gallons and set your current and target levels. Pool math will do the rest, and sow you what you need to add.
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    18,967
    This much:
    The FC level depends on how high the stabilizer level is. If all you've added so far is a few 1" tablets, you're probably down too low to even measure with a test kit. In which case, your target FC is 3. This article explains how to use Poolmath to calculate the dose. Hint: it'll be about 1/2 cup of Clorox 8.25%
    May 2014
    Springfield, IL
    5
    Ok thanks. Yeah I put in some shocker the first day I filled it up about a week ago. Other than that all I've added are chlorine tablets in a floater. Can I leave the chlorine tablets in there when I add the bleach? How long after I add the bleach do I have to wait to swim? Also is it best to add chemicals with the pump on or off?
    Richard320's Avatar
    Jan 2010
    18,967
    Yes, you can leave the floater and if you give the bleach thirty minutes to mix, you can go in, providing the water is clear.
    Patrick_B's Avatar
    Jun 2011
    Midland TX
    14,998
    This much:
    Whoever photo shopped that messed up big time. What's wrong with the picture? LOL
    To the OP, that little pool won't take much bleach at all over the course of a season. Enjoy your summer with it!
    Essential Links:
    Charlie_R's Avatar
    May 2013
    Mexico, MO
    2,156
    I thought it would be the placard, but a quick google shows that 1791 is a hypochlorite solution, strong enough to be highly corrosive.
    Maybe they didn't want their car showing in the pic and shopped it out? You can see a small piece of shadow in the upper left of the rear panel on the tank.
    May 2014
    Springfield, IL
    5
    I figured with as small as my pool is it shouldn't take too much upkeep but if this year is successful I'm thinking of getting a bigger pool next year so I'm in training I appreciate the help. Added half cup this morning and tested just now and I'm at 3 with my chlorine level. Thanks again.
