Thread: Whats with the psi?
    May 2014
    Long Island, NY
    3
    Whats with the psi?
    New Member but Third year with our 15' AG pool. Opened to clear water thanks to BBB. Added new DE to our Hayward filter after started it up AND the psi stayed at 6. The past two years it was between 10-12. What could b wrong? Pressure feels a little light running into pool. THANKS
    15' round 5.7K gal AG vinyl pool; Bleach; Haywood DE filter; Haywood 1 1/4 pump; 4-12 hrs; Taylor K-2006 Tester; utility water;
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    18,967
    Re: Whats with the psi?
    Could be sucking air or have a clogged impeller. Was there any devris in the skimmer that could have gotten sucked in? It could also be as simple as a gauge that went bad.
    May 2014
    Long Island, NY
    3
    Thanks..bled air release, skimmer was closed off from debris.Gauge seems to be working....Can we check impeller without losing water? Its running now at the low psi..Is that dangerous??
    Thanks again..
    M
    15' round 5.7K gal AG vinyl pool; Bleach; Haywood DE filter; Haywood 1 1/4 pump; 4-12 hrs; Taylor K-2006 Tester; utility water; summer: solar;
