Thread: I am going to bond our pool before I back fill it
    Jun 2013
    Newcastle, Oklahoma
    508
    Exclamation I am going to bond our pool before I back fill it
    i am going to bond our pool before I back fill it. Im going to use #8 wire all the way around and connect it to 4 points of the pool plus the screw on the pump. On the water bonding... If I bond the pump... water travels though the pump, and in fact stays in the pump and lines when the pump is off, at least on the suction side, so since the water is in the pump, in the line, and the pump is bonded, then wouldnt the water already be bonded too since it is in the pump and lines? Seems to me that a water bond through the skimmer as I see most done is overdoing it, since its already bonded through the pump.
    Partially buried Doughboy Desert Spring 16 x 32, sport pool, with 7 ft deep middle, 20,000 gallons, Hayward Powerflo Matrix 1.5 HP 2 speed pump, 250 lb sandfilter, 2 Doughboy skimmers and 2 returns. 2 cascade fountains.
    Taylor K-2006 kit. Zodiac Barracuda Ranger suction side cleaner.
    TFPC method and is crystal clear every day thanks to TFP!!!
    Jun 2012
    western NY
    1,562
    Re: I am going to bond our pool before I back fill it
    I would suggest reading Article 680 of the current NEC code as well as discuss with the inspector for this job what he will want to see. Since the pump housing and impeller are all plastic, there is no water connection to the metal pump motor housing. It has been discussed in the past about using the heater heat exchanger as a water bond but the NEC does not recognize that as it can be isolated in some cases.
    Unknown make 18' above ground (bought used in 1999) Sparco sand filter. Hayward 100,000 BTu heater. 2 speed pump
    The water bond needs to have a large surface area. Even the plates often used in the skimmer, far larger than the area of metal contact in the pump, are not sufficient in my opinion (though they do met code requirements).
    Jun 2013
    Newcastle, Oklahoma
    508
    i see. Jason, here is my bonding plan:
    16 x 32 Desert Spring. Only the buttresses are metal on this pool, the other supports are resin with a metal plate top and bottom. I thought about using self taping sheet metal screws and attaching the lugs to the buttresses on the outer two on each side. I would run the #8 wire all the way around the pool. Then I would connect the pump to the grid as well as a water bond through the skimmer that would also connect to this grid. in this diagram, the black squares are the buttresses.
    thoughts?
    If the walls are metal/conductive, that is fine. But if the walls are non-conductive you need to bond each buttress separately.
    Jun 2013
    Newcastle, Oklahoma
    508
    Quote Originally Posted by JasonLion View Post
    yes. walls are steel. Thanks Jason!
