Thread: High Alkalinity
    Louisiana
    127
    High Alkalinity
    Not sure if I am doing something wrong but I just installed and filled my pool 3 days ago with City water and having troubles getting alkalinity down. Currently 170 and I have PH at 7.0. Everything else is good.
    27' Radiant Metric, 17,100 gallons
    Pentair Dynamo 1.5hp 220v
    Circupool RJ45, Sand Filter, Borates
    Dolphin DX6 Robotic cleaner
    TF 100 Kit
    Re: High Alkalinity
    If you provide some sort of aeration, the PH will go up, and you will be able to add more acid to continue lowering TA. More generally, lowering TA takes a while, even with lots of aeration.
    Louisiana
    127
    Re: High Alkalinity
    Thanks Jason. So I need to raise PH up again and then add more acid? I thought by keeping PH down it would lower Alk.
    TF 100 Kit
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    19,051
    Re: High Alkalinity
    Acid lowers pH and TA. Aeration raise pH up so you can repeat it.
