Thread: Help me identify this mult iport valve PLEASE sticker reads 27-2599 6/98 need clamp
    May 2014
    hopkinsville ky
    1
    Hello, filter is pac fab ta 60d
    label on multiport valave is 27-2599 6/98
    i removed the clamp pulled the valve and took the very old sand out, went to put sand backin and someone "stole"" my CLAMP
    i dont know what clamp to try and buy since i really cant identify for sure the valve i have.
    please help
    mack
    elwood58's Avatar
    May 2012
    Sun City West Arizona (2nd Home)
    651
    Re: Help me identify this mult iport valve PLEASE sticker reads 27-2599 6/98 need cl
    27-2599 is actually the Part Number for the Valve Label, and not the six way Valve. The Valve is likely made by Pentair. Check out this link and see if it helps. Item #14 may be what you are looking for.
    19204 Gallon L Shape with a 10X10 2nd Step Baja Ledge. Intellichlor IC-40, IntellipH, Cartridge Filter, Pentair Heater/Chiller (Heat Pump). Tons of Deck with Deck Jets. Construction Complete 6/5/17.
    "If you don't measure it, you can't manage it!"
    Divin Dave's Avatar
    Oct 2013
    Longview, Texas
    5,003
    Hey Elwood,
    man you forgot the link! LOL
    Divin Dave,
    elwood58's Avatar
    May 2012
    651
