Thread: FC and swimming
    Jul 2012
    Forest, VA
    79
    FC and swimming
    I am sure that this question has been asked before but with the holiday weekend in full swing I wanted to make sure as I am entertaining guests this afternoon
    What are the safe levels of FC to swim? If not a safety issue....what would be okay for swimmer comfort without bleaching a suit.
    Test Results:
    FC 9.5
    pH 7.6
    CC 0
    Alk 130
    CYA 60
    12,000 gal Octagon vinyl in-ground pool. Hayward S220 sand filter 3/4 hp pump, heat pump heater
    Butterfly's Avatar
    South Carolina
    10,045
    Re: FC and swimming
    Generally, anything above the minimum and under SLAM level. With CYA of 60, that is between 5 & 24.
    You're done SLAMing when:
    pwrstrk's Avatar
    Elverson Pa.
    4,758
    FC and swimming
    Everything there looks good. Get wet !
    You can swim in FC levels up to SLAM level as long as you can see the bottom of the pool. SLAM level for your CYA level of 60 is 24. 😎
    Jeff
    Jul 2012
    Forest, VA
    79
    Re: FC and swimming
    Thanks for the responses folks! Kids are anxiously waiting for the "go, no go"
    Jul 2012
    Forest, VA
    79
    Re: FC and swimming
    Jumped on in the pool. Everything seems fine except the slimy feeling of the water on my skin. Could it be the sunscreen, high TA? any thoughts?
    pwrstrk's Avatar
    Elverson Pa.
    4,758
    Re: FC and swimming
    Could be the sunscreen. Nothing in your test results points to anything. I have never heard of high TA causing a slimy feeling on the skin. 😎
    Jeff
