Results 1 to 7 of 7
Thread: A couple questions before testing my fill water
    Nov 2013
    Miami, FL
    348
    Question A couple questions before testing my fill water
    I received my TF-100 test kit this week and wanted to test my fill water. I anticipate my build finishing up in about 3 weeks or so and filling the pool with city water.
    Does it matter how I collect the water samples? Take water from the my kitchen faucet or from the outside hose? It is ok to fill a larger container with the water and then dip the test containers into it?
    For the Taylor K-1000 test kit (I want to do the PH test), there are several sheets of "paper towels." What are they for?
    Swimming!: 19x32 IG rectangular pool, 22,500 gallons; 3' - 6.5'; open spa w/ 6 jets; raised wall w/ 1 sheer descent and 2 minijets, 2 color-changing LED pool lights, 1 spa light; Jandy 2 1/2 HP 2 speed Pump, Jandy cartridge filter (320 SQFT), Diamondbrite Cool Blue
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    19,045
    Re: A couple questions before testing my fill water
    Quote Originally Posted by jro33176 View Post
    If you have a household water softener, get the sample from the hose you'll be using to fill the pool. Otherwise, no difference where it comes from.
    Almost all of us old-timers gather one big sample and carry it somewhere comfortable to do the testing. If you have a pitcher or plastic measuring cup with a pour spout, even better.
    The paper towels are to absorb the drips if you put the block away damp. They also provide a nice white background.
    Don't test CYA. Tap water won't have any so you'll be wasting the reagent.
    The "paper towels" are just to keep things from vibrating and moving around during shipping.
    It doesn't make much difference how you collect water samples from the tap. Taking water samples from the pool has a few simple rules, but just about anything works for tap water.
    Nov 2013
    Miami, FL
    348
    Ok, thank you!
    Here are my results:
    pH: over 8.2 (my water color was darker than the 8.2 mark)
    TA: 50 (a light red color)
    CH: 100 ppm
    Is there a preferred order to bringing each of these parameters into range? Do them all at once?
    Lower PH first, then test TA again and adjust TA as needed. Deal with CH only after PH and TA are appropriate.
    And don't forget chlorine! Added after adjusting PH.
    Richard320's Avatar
    Jan 2010
    19,045
    Isn't the pool builder going to do the startup?
    http://www.troublefreepool.com/conte...w-pool-plaster
    Nov 2013
    Miami, FL
    348
    I will ask PB about the start-up. I checked my contract and it doesn't say anything about it. I guess I'll need to retest all the numbers once the start-up is complete.
