Thread: Pentair WF 28 C wiring problem
    May 2014
    Spring Texas
    3
    I have a Pentair WF 28 C 2.0 HP. Had some work done on the motor, now have to reconnect it to the system. Thought I could remember where 3 little wires go too, but no, so I could use a little help please. From the wiring diagram it looks like it is wired for high voltage, (white wire is on B, Brown wire on A). The 3 wires that need to be connected are a green (know where that goes) a red and orange wire. Diagram doesn't state where the red (assuming that's the hot wire) goes or the orange wire. I have attached the all the pictures. Any help would be greatly appreciated, thank you.
    Dave
    Re: Pentair WF 28 C wiring problem
    The two power wires connect to the two central connectors, neither of which has any wires going to it in the photo. They should be labeled L1 and L2.
    May 2014
    Spring Texas
    3
    The three wires that I have to choice from, are green (know where that goes) red and orange (attached photo) does the read go to L2? thanksphoto (3).JPG
    Green goes to the ground terminal on the chassis.
    The other two connect to L1 and L2 (in either order).
    May 2014
    Spring Texas
    3
    Great thanks. This has saved me soooo much time...you are the best
