Thread: Draining and starting over, advice appreciated.
    I have a 23,000 gallon above ground pool with a vinyl liner, 1.5 HP pump with sand filter. Our water is very green and our liner feels like sandpaper. We are in the process of draining now. Any advice is appreciated. Thanks!
    [center:24l4i2yw]3 year old 30' round/54" wall, 23,000 gallon Tahitian AG with a vinyl liner. 1.5 HP pump with sand filter system.[/center:24l4i2yw]
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    18,995
    Re: Draining and starting over, advice appreciated.
    Leave at least a foot of water in the shallow end or the liner may shift or wrinkle. And if the pool is empty, a good wind could push a wall in.
