Results 1 to 8 of 8
Thread: Test Results
    Apr 2013
    Willard, Ohio
    20
    Test Results
    Last year, I switched to TFP and had to do a 75% drain and refill to bring my CYA level down to normal. Overall, had a great 1st year with TFP. Could not believe how easy it was with only bleach!
    Just opened the pool and got these initial results:
    FC 4
    CC 0
    PH 7.2
    TA 110
    CH 180
    CYA 35
    PoolMath says all I need to add is borax to raise PH. I assumed FC would be 0 and I would have some CC. Is it normal to open a pool with ready to swim readings? Do I still need to SLAM? Water is clear and sparkling. This just seems way too easy - I must be missing something...
    15K gal, 24' round AG, 75 sq ft cartridge filter, 1 HP 2 spd Jacuzzi pump, June 2004 install
    Former (& fed up!) 9 year Litehouse Pools customer 2004 - 2012!!
    Joined TFP in 2013 - swimming more and spending less $$!!
    Mod Squad JVTrain's Avatar
    Feb 2014
    Central Minnesota
    5,080
    Re: Test Results
    I would say no SLAM needed. Your pH I would just leave alone. Point your jets upward or swim in it a bit to aerate. PH should rise naturally with aeration.
    Isolated Spa - 345 Gallons
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    19,071
    Re: Test Results
    Happy Opening Day!
    To be sure, these readings are after the water has had an hour or so of pump circulation to mix it all up, right?
    You could just set things up to aerate the water which will bring the pH up with no added chemicals. Point a return up, or build a contraption (lots of pics here if you search "aerator") or use a lawn sprinkler when you top off the water instead of just dropping the hose in. Anything to get teh water bubbling will help.
    And it's very common for TFP people to have a super clear pool when they open. The one-day opening.
    Butterfly's Avatar
    South Carolina
    10,045
    Re: Test Results
    ^^^ what they said
    And don't forget to post some pics for us!
    You're done SLAMing when:
    Apr 2013
    Willard, Ohio
    20
    Re: Test Results
    We have had some strong storms and heavy rain over the last week or so. A little concerned about higher pH and lower CYA readings.
    8.2 pH (aeration from rain?)
    7.5 FC
    0 CC
    120 TA
    180 CH
    20 CYA (was 30 at startup - could still see dot at 25 this morning - rechecked twice)
    Should I add something for the pH and CYA, or give it some time?
    Butterfly's Avatar
    South Carolina
    10,045
    Re: Test Results
    First lower the pH to about 7.4ish.
    Add enough CYA via sock method to get back to 30.
    30,432
    Re: Test Results
    I am fairly surprised your pH went from 7.2 up to 8.2 in just 25 days. Rain typically has VERY little to do with it.
    If it were my pool, I would record a daily log of pH and see if that trend continues (after you lower it per BF's suggestion)
    Apr 2013
    Willard, Ohio
    20
    Re: Test Results
    After Muriatic acid and CYA sock treatment, here are today's results:
    FC - 7.5
    CC - 0
    pH - 7.6
    TA - 110
    CH - 170
    CYA - 40
    Pool is clean, chemistry looks good, but water is a little dull. Not cloudy, but not crystal clear. Anything I can do to improve clarity? Vacuuming twice a week and cleaning filter weekly. I have 2 filters so they get swapped out each week.
