Page 1 of 2 12 LastLast
Results 1 to 20 of 23
Thread: Cloudy Water and Balance Issues - New Pool Owner
    kadeshpa's Avatar
    May 2014
    Manalapan, NJ
    13
    Hi guys, new to the pool ownership game. Have been trying to balance my pool for the past week and so far unsuccessful. I am following the BBB method after mistakenly following advice of Lowe's and shocking my pool with Aqua Chem Super Shock Plus.
    I have since reshocked based on the pool calculator and added 5 gallons of bleach last night (9pm). So here are the readings utilizing a Taylor K-2006 FAS-DPD complete kit as of noon today.
    FC = 9.2
    PH = 8.0
    TA = 40
    CH = 50
    CYA = 25
    Pool Temp - 72 F
    I have a 22x34, 24000 gallon IG Gunite kidney shaped pool with 2 skimmers and 2 returns. The depth of the pool is three feet to seven feet ten inches. It is approximately 20 yrs old (purchase with house this October). The pool equipment is in good working order and I have backwashed the Sand filter and primed the pump. The filter has been online for 48hrs after shutting off earlier this week.
    My Equipment is:
    Hayward Pro Series sand filter with a multi-port
    1.5 HP Hayward super pump and motor
    Hayward H Series 250,000 BTU natural gas heater (currently offline)
    Smykowski's Avatar
    Sep 2011
    3,065
    Re: Cloudy Water and Balance Issues - New Pool Owner
    Welcome to the forum!
    Good on you for getting the good test kit. Next step is to lower your pH to 7.4, then continue the SLAM (I noticed you used the word "reshocked" above). The SLAM is a process that will take at least several days, but will clean the pool and make it sparkly again.
    kadeshpa's Avatar
    May 2014
    Manalapan, NJ
    13
    Thank you!
    Does the Calcium level seem too low? The pool calculator says it should be in the range of 250 - 350 and I'm at 50. Do I wait to add CC or add while SLAMing?
    kadeshpa's Avatar
    May 2014
    Manalapan, NJ
    13
    Oh and I didn't mention that my CC = 0 when I tested at noon.
    Smykowski's Avatar
    Sep 2011
    3,065
    Sorry, let me back up for a second.
    How does the water look?
    You are correct about your CH. I would bring CH up to 250, TA up to 80, and pH down to 7.4 or 7.5, no matter how the water looks.
    kadeshpa's Avatar
    May 2014
    Manalapan, NJ
    13
    Water actually looks nice and blue, it's just cloudy to the point that I can't see the drains, i.e., pool floor.
    I looked at Home Depot and they sell Calcium Chloride as Ice Melt. 50lb bag is 17.99. Calcium Hardener at Leslie's is 62.99. I'm assuming these are similar products? If not, what do you use? I think the Leslie's stuff is your typical overprice specialty product.
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    19,074
    Welcome!
    Lower pH with acid.
    If you're sure of that CH reading, then adding some Calcium would be a good idea.
    You're in the rare position of being able to efficiently using Cal-hypo "shock" powder to chlorinate if you want. Just be sure to read the label to be sure you pick the right "shock." Using poolmath, it looks like as much as 50 pounds of 73% Cal-hypo wouldn't overload you on CH. Buy a bucket of it and then just use it in place of liquid bleach. Poolmath can still calculate the dosage. When the bucket is used up, switch back to bleach Be forewarned that adding any Calcium product can cause cloudiness.
    kadeshpa's Avatar
    May 2014
    Manalapan, NJ
    13
    OK great thanks. I'm taking a test sample of the water to a local Anthony & Sylvan Pool Shop to get the results confirmed. I will then adjust accordingly. Thanks again.
    Richard320's Avatar
    Jan 2010
    19,074
    Quote Originally Posted by kadeshpa View Post
    Don't do that! You'll just end up confused. Repeat the CH test. Read the instructions carefully to be sure you didn't use the wrong drops or something. It either turns sky blue or it doesn't. If you can count and do simple multiplication, you can do it!
    kadeshpa's Avatar
    May 2014
    Manalapan, NJ
    13
    OK, then when I did that it took 5 drops of the R-0012 reagent, so I'm at 50ppm CH. I'm going to go ahead and do another full test.
    kadeshpa's Avatar
    May 2014
    Manalapan, NJ
    13
    OK just re-ran. I had put another bottle (121oz) of bleach in about 2 hours ago fyi.
    FC = 11
    CC= 0
    PH = 8
    TA = 40
    CH = 50
    CYA = 25
    So based on this I'm going to go ahead and buy some Cal hypo 73%. Muriatic Acid to lower pH and Baking Powder to increase TA.
    Richard320's Avatar
    Jan 2010
    19,074
    FC = 11
    CC= 0
    PH = 8
    TA = 40
    CH = 50
    CYA = 25
    Now remember: you're using the Cal-hypo instead of liquid bleach. Don't put it all in at once! Use it for daily chlorination until it's gone, then switch to bleach. You may not need to buy any more chlorine products for months.
    kadeshpa's Avatar
    May 2014
    Manalapan, NJ
    13
    Got it...Thank you!
    kadeshpa's Avatar
    May 2014
    Manalapan, NJ
    13
    I purchased some CC as well from the pool store. At 50ppm CH I was worried that waiting for the Cal-hypo to up my CH would take too long and adversely affect the pool plaster.
    Richard320's Avatar
    Jan 2010
    19,074
    Just so you know, CC is our shorthand for Combined Chlorine, which is undesirable. CH Increaser is what we call Calcium Carbonate. You'll get people all confused and excited if you keep reporting on high levels of CC!
    kadeshpa's Avatar
    May 2014
    Manalapan, NJ
    13
    Woops....got it.
    Jul 2011
    Austin, TX
    61
    A double check???
    I have a TF100 test kit using the same reagent, and 5 drops would be 125 (5x25). You calculated 50.
    You may have a different kit using different calculations; but I thought I'd speak up just in case....
    16,000g in-ground plaster pool, attached spa, BBB, DE Filter, SWG
    There are two ways to do the CH test. When using a 25 ml water sample, each drop is 10 ppm of CH. When using a 10 ml water sample, each drop is 25 ppm of CH.
  20. Back To Top    #20
    kadeshpa's Avatar
    May 2014
    Manalapan, NJ
    13
    OK rerun at noon and here are my results (note, added cal-hypo to get to 16 shock, added baking soda and calcium chloride to up my TA and CH and added Muriatic Acid to lower pH)
    FC = 11.2
    pH = 7.4
    TA = 80
    CH = 150 (added roughly 20lbs of cal chloride last night)
    CYA = between 35 and 40
    Blind vacuumed pool yesterday and backwashed as my psi was going too high afterwards.
