Thread: Existing backyard Drain on pool location
    May 2014
    Brentwood, CA
    76
    Hi everyone, I am new to this forum and also a first time pool owner. We just bought the Intex 18' x 48" round pool 4 days ago and I started removing the sod in my backyard to level the site following the sound advice of people in this site. And after leveling, I will put play sand before I set up the pool. I have also decided to dig a trench and install a GFCI outlet about 6' from the edge pool because the pool is too far from the nearest wall outlet in our backyard. I am also capping off the sprinklers on the pool location. So I hope I am doing the right thing.
    My concern now is the existing backyard drain that I uncovered when I removed the sod. If you can visualize the pool in 4 quadrants, the drain sits in the middle of one of the quadrants. I can't move the pool site because that is the only place available for the pool. As you can imagine, the ground slopes towards the drain. So I am not sure what to do. And I have read that if you want to level the ground, use the lowest point as your point of reference. Should I relocate the drain, cover it or just leave it alone? There are other existing drain locations in our backyard.
    Thanks for your help in advance.
    Casey's Avatar
    SW PA
    10,423
    Re: Existing backyard Drain on pool location
    If you can move the drain easily then do so.
    May 2014
    Brentwood, CA
    76
    Can I just leave it since I plan to take down the pool late fall every year?
    Intex 18' x 48" Ultra Frame Round Pool - AG, Intex Krystal Clear Model 28633EG 2500 Filter Pump, Intex Krystal Clear SWG #28663EG, TFT100 Test Kit, Hayward Skimmer
