Thread: Replacing Leaking/Broken Return
    rharlowjr's Avatar
    Jun 2013
    Brooklyn, CT
    14
    Last Year: NOOB Opened pool at new house for the first time. Broken AquaLight return was leaking. Waited 'til this year to fix.
    Now:
    1) The liner tore slightly around the return hole, so I patched it.
    2) I cross cut the liner where the return hole is--as opposed to trying to cut a circle.
    3) Replacing return with Hayward SP1023G w/ 1-inch eyelet.
    The return has a double gasket
    The above gasket fits the return hole fine, however when I try to install the gasket with the liner/patch pulled through the hole (as in picture 2) it does not fit properly.
    QUESTIONS:
    1) am i right to assume I should be installing the gasket this way? It seems to make the most sense (even though it doesn't fit)?
    2) should i install the gasket in the wall of the pool and pull the liner through that (does that defeat the purpose of the gasket)?
    THANKS IN ADVANCE!
    --Russ
    Brooklyn, CT
    AG round, 24' x 3.5' deep, 13k gal, vinyl-lined pool, sand filter--31.5 gpm, 1.0 hp pump
    Re: Replacing Leaking/Broken Return
    The flaps of liner material get cut off. Typically the liner gets fit in-between the wall and the inner part of the gasket, so you have gasket - liner - wall - gasket. Some setups provide a second gasket so it ends up being second gasket - liner - gasket - wall - gasket, but that is less common.
    rharlowjr's Avatar
    Jun 2013
    Brooklyn, CT
    14
    I do have a second rubber gasket (and a third cork gasket).
    I trimmed the liner/patch
    But the gasket still bunches
    I'm guessing the liner needs to be almost precisely the same size as the hole for the return and not go through the hole at all.
    Should I add any silicone/caulk at all?
    --Russ
    Brooklyn, CT
    The Hayward SP1023G comes with a "sandwich" gasket. Therefore when replacing the "sandwich" gasket it goes as follows:
    • Inside pool SIDE goes between wall and backside of pool liner
    • Outside pool SIDE goes outside pool
    The ordering of gaskets to parts is:
    • Inside pool
    • Rubber gasket
    • Pool liner
    • 1 side of "sandwich" gasket
    • Pool wall
    • Other side of "sandwich" gasket
    • Cork gasket
    • Outside pool
    22,833 gallons
    Cartridge
    AG
