Results 1 to 7 of 7
Thread: How often and how much bleach and muriatic acid
    Feb 2014
    Houston, TX
    7
    Hi there
    I realize everyone's pools is different but I wanted to get a ballpark to see if I'm anywhere close. How often and how much bleach and MA do you usually add. I find that I've been having to add a quart to half gallon of bleach every other day. Also maybe a full gallon of am weekly. This seems a bit much as I think most don't have to add MA often. I am using borax for borates and it's around 80. Thanks for everyone's advice and feedback!
    My ta is 100 btw
    21k galloons IG pebblesheen chlorine
    Rainbow 320 Chlorinator; Cartidge Filter Pentair 520
    1 Pentair Intelliflo Variable Speed, 1 1.5HP Whisperflo for water features
    Pentair Legend Platinum Cleaner
    Pool completion date: 1/25/2014 TF-100 test kit with SpeedStir
    Re: How often and how much bleach and muriatic acid
    I add 2 ppm of chlorine daily, and no acid at all.
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    18,974
    The bleach sounds reasonable, considering the size of your pool.
    The acid sounds a bit extreme, but I was using that much until I finally knocked the TA down for keeps. How long has it had that thirst for acid? A few weeks, or for years? And is that full-strength acid, or that half-strength low-fume stuff they sell at the hardware stores now?
    Jan 2012
    'burbs of Augusta, Georgia
    7,306
    Quote Originally Posted by cc517 View Post
    Hi there
    My ta is 100 btw
    I don't have a gunite/pebblesheen pool but *think* that Ive read here that the first year takes more acid tweaking with MA until it ages up a bit? Can one of the pros here confirm or correct this? I see the OP siggy line shows his pool is brand new.
    Richard320's Avatar
    Jan 2010
    18,974
    Good catch, Skippy! New plaster will use a lot of acid.
    Patrick_B's Avatar
    Jun 2011
    Midland TX
    14,998
    I'm about 4 weeks into a new fill/new pool and my acid use has just subsided. My TA is down to about 80 and I'm only adding acid every other day or two now. For a little while I was using nearly a gallon a day in 29000 gallons. I started with a TA of about 190, but I too know that the lower TA is a major reason my pH rise is calming down. My fill water runs around 7.75 pH and this doesn't help.
    Give it some time and yours should calm down too.
    Essential Links:
    wjr75's Avatar
    Jun 2013
    IL
    836
    Just had a Pebble sheen refinish about a week ago. The first four days I used a 1/2 gallon of MA per day. At 11 days it has stabilized and I just need a swig per day.
    Inground 22k gallon gunite 15x31 main pool, 15x7 wading pool/sunning deck, hot tub/with overflow (9' octagon with limestone top) & slide NSWG, Aqua Blue Pebble Sheen
    Filter dual cartridge Sta-rite 450sq/ft, TF-100 Test Kit
    Heater Raypak 2100 400k btu cupro-nickel exchanger
    Auto pool cover, Polaris 280 auto pool cleaner, Jandy AqualinkRS8 Remote Control System
