Page 1 of 2 12 LastLast
Results 1 to 20 of 25
Thread: Lower PH, increase CYA
    Jul 2011
    Brookfield, WI
    131
    Hello all!
    I just tested my pool and got the following readings:
    FC: 29
    CC: 00
    CYA: >20
    PH: < 8.2
    TA: 190
    CH: 330
    So, I get puzzled why I always get a 0 for cc, but not sure if that makes much of a difference. I will do further reading on the pool school. The issue here is that I need to lower PH and raise CYA. In which order shall I do that? I shocked the pool yesterday using common bleach. I added 13 gallons of it as the water was rather fishy smelling. I am sure most of it may be burned by the end of the day...All suggestions and advices are welcome.
    Thank you and enjoy this beautiful day!
    20 x 44 in-ground vinyl
    Hayward Pro-Series High-rate sand filter (S310T)
    Nature2 Zodiac chlorinator
    pwrstrk's Avatar
    Elverson Pa.
    4,758
    Re: Lower PH, increase CYA
    I would lower the PH first to the mid 7's then add CYA to the desired level. 30-50 for a non SWG pool and 70-80 for a SWG pool.
    The CYA is acidic and will lower the PH a little. Pool Math at the bottom, Effects Of Adding Chem's, will tell you how much. 😎
    Jeff
    Charlie_R's Avatar
    May 2013
    Mexico, MO
    2,156
    Lower your pH, then add 1/2 the amount of CYA that PoolMath suggests to a sock and either place in your skimmer or tie in front of a running return, leaving the pump running until it dissolves. Remember, CYA will generally not show up on your test for a week after adding. It need time to be fully mixed into the water.
    0 CC is a good thing! Means that the chlorine is doing it's job well.
    Jul 2011
    Brookfield, WI
    131
    Thank you for the replies. I will add the Muriatic acid and then get some CYA to put in the skimmer. I have some Muriatic acid from last season. Is it possible for it to get old and loose its effects?
    Oh, another thing. How soon can the kids swim after adding muriatic acid?
    pwrstrk's Avatar
    Elverson Pa.
    4,758
    20-30 mins and you can let the kiddo's in the pool.
    Your CYA from last year will be fine. It was kept sealed up right ? 😎
    Jeff
    Ellington, CT
    262
    Quote Originally Posted by pwrstrk View Post
    But with FC at 29 and cya less than 20 the FC is way over SLAM level so isn't still not safe to swim?
    30,000 gal, 20 x 40 ft vinyl, IG, installed 2006
    1 HP WhisperFlo pump, 60 sqft Pentair Quad D.E., Liquidator(8 gallon) with 3/8 upgrade, AquaVac TigerShark cleaning robot
    TFTestkits TF-100 with SpeedStir, WS
    A proud practitioner of TFP since 2013
    pwrstrk's Avatar
    Elverson Pa.
    4,758
    Whoops forgot about the FC level. Let that drift down to 10 or below.😎
    Jeff
    Jul 2011
    Brookfield, WI
    131
    Thank you. The water is cool anyway, so the children will stay away. With my CYA so low, I am sure that most FC will be lost by the end of the day as we are expecting a very beautiful, bright sunny day! Muriatic acid is already added to the pool!
    Jan 2013
    Houston, TX
    1,079
    You may want to take a close look at the slam ( shock level and maintain ) process in pool school. Arbitrarily adding 13 gal of bleach isn't good for the pool or the pocketbook.
    TFP Moderator Chris V. ~16K Pool & Spa, 48NSF DE, IG Plaster Circa 2000, Intermatic PE653, Challenger pump with a 2 speed B2984, 20gal stenner chlorine injection, Houston, TX
    One cannot follow Islam and Christianity at the same time, nor can one follow pool store methods and TFP at the same time.
    Pool School -- Pool Math -- TF-Test Kit
    Jul 2011
    Brookfield, WI
    131
    I id not think it as a good idea, however the stink of dead fish was way more than I could handle. I have never added that much chlorine to the pool, this time was an exception and once i get the numbers in balance I am sure I will need not need to slam it anymore. Thank you for the input and advice, nonetheless
    Jul 2011
    Brookfield, WI
    131
    So, this morning I performed another reading of the FC and ph. Here are my new numbers:
    FC: 3
    PH: 7.5
    So, I got the Ph balanced and, as expected, most chlorine got burnt with the sun yesterday. I added 7 sticks to my skimmers and will wait until next Sunday to take a reading of the CYA. I am considering adding a gallon of chlorine tonight, just to make sure I do not get the "fish" back on my water. Is that a good idea? Will the sticks be able to dispense enough chlorine to keep the water sanitized?
    Oct 2013
    Chapin, SC
    1,141
    You haven't mentioned what kit you're using to test your water or how much cya you have used so far or your target for cya. That info could be helpful.
    Pool size: 24000gal inground Vinyl-Taylor k-2006 and k-1766 test kits and-speed stir
    Intermatic P1353ME digital timer w/freeze sensor
    CircuPool Si-45 SWCG System
    Polaris 280 vacuum/Polaris PB4-60 boost pump
    Pentair IntelliFlo VS 3hp Pump--Pentair sand filter
    Jul 2011
    Brookfield, WI
    131
    I did not add any Cyanuric acid, other than the sticks I added to my skimmers. As for my kit, I use TF-100
    pwrstrk's Avatar
    Elverson Pa.
    4,758
    Is your plan to use the sticks until you reach your desired CYA level then stop with them ?
    At the bottom of pool math, Affects Of Adding Chem's you can figure out how much each stick is raising your CYA level. 😎
    Jeff
    Jul 2011
    Brookfield, WI
    131
    That's my plan indeed. I do not wish to keep the sticks going season around. However, I will check the pool math and wait until the end of the week to take another reading. I will add more chlorine, as I do not believe the sticks will be able to keep a minimum considering the non existent CYA. Does that sound reasonable or am I on the wrong course?
    Charlie_R's Avatar
    May 2013
    Mexico, MO
    2,156
    As long as you are aware of what is going on in your pool, what you are doing should work.
    Jul 2011
    Brookfield, WI
    131
    Thank you Charlie. I am monitoring it closely and will post an update at the end of the week. Hopefully the CYA will be at a decent level.
    Jul 2011
    Brookfield, WI
    131
    During the week, the FC remained at 3 and the PH set at 7.5, The water is crystal clear and delicious. I take the cover off during teh day so the temperature can raise up. I added a jug of chlorine last night and this morning the readings were as follow:
    FC: 8
    CC: 0
    PH 7.5
    CYA >20
    The skimmer has the sticks, which are doing something, but the CYA remains low. I will give it few more days and may add a bit of acid. The children are swimming already, so I will be monitoring the FC to make sure the water stays sanitized.
    Any other thoughts that I need to take in consideration?
    Thanks again.
    Jul 2011
    Brookfield, WI
    131
    So, it has been 10 days since I added the sticks and the CYA has not increased at all. Days are beautiful and very sunny, so the chlorine is burning fast. Took a reading this morning and the FC is sitting at 2.5. We did have a bunch of rains in the past few days, so the level of water increased. I did add 2 jugs of clorox on Wednesday, but clearly that got burned off too. So, now I want to ask a brand for CYA that I can purchase locally. I will do the math to figure how much I nee to add. I appreciate the help. Have a beautiful sunshine day!
  20. Back To Top    #20
    Smykowski's Avatar
    Sep 2011
    3,065
    Look for anything with the label "conditioner" or "stabilizer," then check the ingredient list and look for 100% (or close to it) cyanuric acid. Wal-Mart and Menard's both carry something. It's just a matter of finding a good price per pound.
