Thread: Pump timer maintenance
    AnnaK's Avatar
    Jul 2007
    Eastern Pennsylvania
    1,134
    This is a heads up to check your timer every so often, if you have one.
    We have the Intermatic T101R, set with two screw-on tabs, one to turn it on, the other to turn it off. One of these tabs tends to work itself loose, probably from the physical vibration when the timer sets itself and the times when I set it manually during its off-hours. When it loosens it rides at the 6 0'clock position on the clock wheel, by gravity. Obviously, the pump can't come on that way.
    I'm hesitant to put any sort of locking compound on it because I may want to change its setting now and then. I just check it every other day to make sure it's still in place and tighten it, if necessary.
    Here is an example of a perfectly simple equipment malfunction which could present you with a 'green' surprise upon return from vacation.
    AnnaK
    12,500 gal AGP, Hayward sand filter, Pentair 2-speed pump, timer.
    Please visit our Pool Issues pages for information about step weights, managing the solar cover, and PoolSkim.
    Apr 2008
    Central California
    36
    Re: Pump timer maintenance
    I've been away for a while (enjoying my pool...finally rid of the "goo") but lurking and reading on occasion.
    I've had similar experience with the timer trippers; finger tight just doesn't get the job done. I've been using a pair of needle nose pliers to tighten the post, almost to the point of putting a dent in the time wheel. Obviously I will need to use the pliers to move the tripper, but at least it stays put.
    On another note concerning these trippers - I wanted to purchase a second set so I can have my filter pump run in the morning and then again in the evening. Went to Lowes, Home Depot, OSH and got the same answer - gee, I can sell you the timer, but we don't have any extra trippers
    Found them on-line - like $2/pair. Bought several sets so I have some spares.
    http://www.poolsaz.com/Intermatic-Ti.../156t1978a.htm
    Mark A. Wolf
    vocation = engineer
    avocation = bass trombone
    homebrewing, swimming pool chemistry - all my home science experiments
    21000 gal gunite IG pool/spa; Hayward Swimclear 3020 cartridge filter, Hayward Northstar pumps (one filter, one waterfall), heater (not sure size), Hayward Navigator
    AnnaK's Avatar
    Jul 2007
    1,134
    Good deal on the trippers! I talked my electrician out of a second set. Haven't used them yet but it's coming up on the really hot season here when I'll be running the pump a few hours during the day as well.
    I just learned that there's a 'medium' strength Loctite that has enough wax (or whatever is in it) to prevent the vibration from shaking the trippers loose but doesn't actually glue them in place like the stuff I used on my old Dodge truck.
    AnnaK
    Jul 2007
    Suwanee, GA
    528
    Yes, there is a blue and a red Loctite. The blue is removable, well so is the Red, but with a lot less cursing.
    Gary
    21k gal SW, IG Gunite PebbleSheen, 1HP Jandy, Jandy 340 filter, Polaris 280, 17' fiberglass slide w/ 2HP pump.
    Jun 2007
    Poughquag, NY
    217
    The Home Depot I went to had the trippers right above the timers in the electrical section (yes, in an unmarked cardboard box that also had other stuff in it). They were a couple of bucks at most, so I bought 2 extra sets.
    I have found that if I use a cloth or gloves, I can get those suckers so tight I can't get them off with my bare fingers the next time around. I have had them slip, so I am paranoid about cranking them down as well.
    I use the 2nd set to turn my pump on at night for about 2 hours. We get a lot of Japanese beetles and some sort of beetle that looks like a minature cockroach and I don't like the thought of them floating around for 10 hours or so.
    20 x 40 vinyl IG. SWG. Solar. Ikeric VS pump.
