Results 1 to 19 of 19
Thread: Sand Filter Gauge Replacement
    amccaul's Avatar
    Apr 2014
    Missouri
    25
    I have decided to replace the cheap gauge on my sand filter with one recommended on TFP forum but mine had 1/2" threads. Is it ok to get a brass reducer to adapt to the 1/4" offered or do I need to keep looking for a quality gauge with 1/2" threads? Just tired of the $5 dollar gauges that get moisture under face immediately...time for an upgrade!
    Leisure Riviera 34 15k Fiberglass IG; Hayward S180T sand filter; Hayward Super Pump dual speed .75/1.5 HP; Pentair PG-2000 Fiber Optic Lights.
    Patrick_B's Avatar
    Jun 2011
    Midland TX
    14,998
    Re: Sand Filter Gauge Replacement
    Well, that is unusual but a brass or PVC bushing will be fine. No need to look for a half inch NPT gauge.
    Essential Links:
    30,411
    Double check that fitting size. I am pretty sure your S180T sand filter comes with a standard 1/4" female connector.
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    18,967
    You are aware that 1/4" NPT threads are close to 1/2" outside diameter? Pipe sizes are given by the inside diameter.
    Smykowski's Avatar
    Sep 2011
    3,065
    Yep. S180T is 1/4" npt threads. I bought the gauges from TFTteskits and they fit fine.
    May 2014
    North Carolina
    18
    ditto - and a nice gauge to boot
    15K, IG, Sunstone Pearl (pebble) finish, Pentair EasyTouch 8 control system, Pentair IntelliFlo VS pump, Pentair IC 40 SWG, Pentair CC200 Cartridge filter, solar heating - 4th time pool owner
    amccaul's Avatar
    Apr 2014
    Missouri
    25
    I ordered the 1/2" and it fit fine so do you think this is 1/4" and store had the one I got labeled wrong?
    38,262
    That is a 1/4" thread fitting.
    amccaul's Avatar
    Apr 2014
    Missouri
    25
    OK thanks, I will order one Tuesday from TFTtest kits...should have ordered one of those when I ordered test kit last week!
    Patrick_B's Avatar
    Jun 2011
    Midland TX
    14,998
    Quote Originally Posted by amccaul View Post
    You will like it I promise. I put one on my brand new filter the first or second week it was in service. Threw the factory one in the trash, and haven't looked back. The new one is easy to read and I know it will last.
    Remember...Don't forget to cut the little tip off the rubber insert at the top so it can equalize. If you don't, your reading will be inaccurate.
    Essential Links:
    amccaul's Avatar
    Apr 2014
    Missouri
    25
    Will there be directions for the rubber tip or is it self explanatory...the cheap ones I have did not have that.
    38,262
    You know, I am not sure I cut the rubber on mind
    Mod Squad JVTrain's Avatar
    Feb 2014
    Central Minnesota
    5,080
    My Wika gauge has a rubber switch. Toggle one direction to equalize, toggle back to reseal.
    Isolated Spa - 345 Gallons
    30,411
    Well, my back mount gauges have a brass "push-pull" toggle to equalize the pressure ( and a label telling you to do so) but the bottom mount gauges have a sealed rubber tip that gives no instructions.
    Brushpup, where did you see to cut off that tip? I won't be able to get to the manufacturer for another hour or two.
    30,411
    Just now heard from supplier. No need to do anything to your gauge if it is on zero when you get it. If it's not, simply remove the plug to let the pressure equal....gauge should go to zero....replace stopper and your done. Don't cut the rubber off.....it's there to get a grip if you need to remove it.
    The rear mounted gauges have that brass push-pull device in the stopper that does the same thing.
    Of the four that I opened to look at, none needed calibration as they were already on zero.
    Hope this helps....I sure didn't know about it 'til now.
    38,262
    I am pretty sure I read about cutting the rubber and just did not do it ... might have been on an instruction sheet with the gauge. Might want to check that. I know I read it somewhere.
    30,411
    Hmmmm! It's a solid rubber seal so by cutting off the tip (on the ones I have) would only serve to make it a little neater looking.
    I have never noticed separate instructions in my inventory but I believe you guys....brushpup must've gotten some, too.
    Anyway, I'm not sure what the point would be.
    May 2014
    Upstate NY, US
    64
    Would the gauge on TFTestkits fit a Jacuzzi 190L with a Seven Way valve?
    My pool: 13,500 gallons round pool, 24' w 52" above ground, hard sided pool. Jacuzzi 190L Sand Filter, 1 Horse Waterway pump, Robotic Vacuum
    May 2014
    Turlock, CA
    55
    Quote Originally Posted by MichaelJTritter View Post
    I googled your filter, and the bottom mount gauge from TFTestkits has the same thread size, 1/4" NPT.
    21K gallon, plaster, 1hp Hayward MaxFlo pump, Hayward 244s sand filter, 3/4 hp Halcyon PB4-60Q booster pump, Polaris 280 cleaner.
