Thread: Pures SMBW Filter Leaking from Discharge Tube
    May 2014
    Grosse Pointe Michigan
    1
    Welcome to TFP! I started a new Thread for your post. Please start a new Thread whenever you have a question or new topic as opposed to posting your question on someone else's Thread (we call that practice "hijacking"). Plus, posting your question in a new Thread is more likely to get responses. --BoDarville, TFP Moderator
    I have a Pures SMBW filter that is leaking from the Discharge tube and a little from under the filter near the center of the discharge handle?
    Is there a gasket or O-Ring kit to repair this leaking?
    Bob
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    19,037
    Re: Pures SMBW Filter Leaking from Discharge Tube
    Welcome, Bob!
    Is this your filter?
    http://www.pentairpool.com/partslist...lters-180.htm#
    It looks like there may be an O-ring at the bottom that can leak. I know after I backwash sometimes I get a drip out the waste port. Moving the handle back and forth a little a few times gets it to seal for me. It's just some grit or DE caught somewhere.
