Results 1 to 9 of 9
Thread: Cloud/tiny bubbles coming from Aqua Rite SWG
    Littlemonkey's Avatar
    May 2014
    Winnipeg, MB
    6
    Hi guys, I had the no flow problem a few weeks ago with my Aqua Rite SWG and replaced the current limiter as per the "fix" that's circulating the internet. No more errors coming up on the board but I'm getting what appears to be a cloud coming out of the nozzles. I posted a youtube video to show you what's happening. I apologize for the bad focus. I think it got set when I began shooting but you should get the gist of the problem I'm having.
    Any ideas or hypotheses? Thanks.
    Casey's Avatar
    SW PA
    10,427
    Re: Cloud/tiny bubbles coming from Aqua Rite SWG
    Hey and welcome to TFP. Bubbles are normal for a SWG but that white cloud, I am unsure of. It looks like your water has algae in it because it isn't that clear and you should actually stop using the SWG and manually dose the pool with liquid chlorine.
    If you have a test kit, please post a full st of numbers and tell us what you're using. to test the water.
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    18,982
    Welcome, eh?
    There sure have been a lot of Canucks joining up lately.
    Bubbles from the SWG seem to be a normal phenomenom. Just search "Bubbles SWG" up above and you'll find lots and lots of threads.
    And that pool looks a bit cloudy around the steps.
    We see this in a couple of pools a year. It usually only lasts a few days, going away when the water gets in balance, or the temperature changes, or something we aren't sure of happens. The white cloud is a cloud of bubbles, and dissipates if given time. Something about the conditions mean that it dissipates more slowly than it is created.
    In any case, I recommend that you more or less ignore the foaming, and start balancing all of your levels, and odds are the foaming will go away in a day or two.
    May 2014
    Winnipeg, MB
    6
    Quote Originally Posted by JasonLion View Post
    I'm sorta thinking along the same lines. The state of the pool is causing some sort of interference with the electrolysis process. I'll get back to you on the measurements in a bit. We have scattered thunder storms on the prairies after reaching 86F today. It's pouring rain right now.
    Thanks for all the replies thus far!
    May 2014
    Winnipeg, MB
    6
    I tested the pool tonight with an HTH test strip:
    FCA = 10
    TCI = 10
    Alk = 120
    pH = 7.8
    TH = 450-800
    CyA = 30-50
    Salt = 3000 (per SWG)
    Temp = 80F
    Water still cloudy but not green cloudy. Shocked it a few nights ago. Added 400g of Pool Clarifier Granules (Aquarius) tonight to the skimmer. SWG is off.
    Those numbers look fairly good. I would lower the PH down to around 7.2 as a start on lowering TA a little, but otherwise everything is fine.
    May 2014
    Winnipeg, MB
    6
    Pool looked better this morning. I could see the bottom of the shallow end. Not covering the pool this year was a mistake. Decomposing oak leaves really mucks things up.
    Measurements this morning:
    FCA = 3
    TCI = 3-5
    Alk = 80-120
    pH = 6.8-7.2
    TH = 250-450
    CyA 0-30
    Salt 3000
    Temp 78F
    Added 300g of Stabilizer to the skimmer this moring. Leaving SWG off until I see some clear water.
    CyA = 30-50
    Temp = 80F
    Jun 2011
    Long Beach, CA
    2,781
    Make sure you are adding liquid chlorine and don't let it drop while the SWG is off.
